Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-16-2009, 08:45 AM
germaza is on a distinguished road
Aligning workpart with edgefinder similar to Mach3 possible?
Hello,
i intend to use EMC2 for my selfmade CNC router. I think itīs a quite nice progam and itīs Linux. As i know from Mach3, with this software it is possible to orient the workpart by touching two points for the first axis and two points for the second axis. So far i found no information on the common EMC2 pages. I added a picture from the Mach3 manual, there you can hopefully see what i mean.
Manfred
Old 10-16-2009, 11:39 AM
samco is on a distinguished road
In the development version of emc2 there is coordinate rotation. (you would have to do the math or have your gcode program do the math - a little trig never hurt anyone. )
http://linuxcnc.org/docs/devel/html/...Set-Coordinate
sam
To try the dev version - the directions are here.
http://wiki.linuxcnc.org/cgi-bin/emc...04_from_source
Old 10-16-2009, 01:04 PM
Hello sam,
as i understand your answer, there is no functionality comparable with the mach3 alignment possibilities integrated in ECM2. Thanks for your answer.
Manfred
Aligning & Tuning new CNC justCNCit DIY-CNC Router Table Machines 11 06-06-2008 01:43 AM
edgefinder krymis Industrial Hobbies (Support forum) 2 01-02-2007 10:40 AM
aligning two objects erase42 BobCad-Cam 11 06-22-2006 05:07 PM
Help Aligning Model NuKkleZ GibbsCAM 2 06-08-2006 03:34 PM
Aligning cnc-table with laser? samualt DIY-CNC Router Table Machines 4 11-17-2003 09:33 AM
