| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hello Community After a few years with Stepper driven CNC machines I decided to build a real Servo CNC with 4 Axxis. I found EMC2 and tried something with the parallel Port (to slow !). So I ordered a Mesa 5i20 Card read the documentation and designed four PWM Amplifiers with low active Inputs. Most everything works well, but the PWM polarity is wrong ! I need pure high Level on 0% PWM and a pure low level at 100% PWM. After some hours with the Hal pins I decided to change the BIT File for the Mesa Card. I want to add a new hm2_5i20.0.pwmgen.00.output-type (4) for inverted PWM polarity. I´ve downloaded the ISE 10.1 Webpack from Xilinx (what a mess). Can anyone help with a tutorial adding the sources and compiling a new .BIT file for the FPGA ? Thanks for any Help Best Regards Bernd PS: english isn´t nativ to me |
| Greetings If you really need a new bit file Peter at Mesa probably could help you. He is subscribed to the EMC maillist. But I'm not sure you need to. I'm pretty sure you can inver the PWM pin. It's just a little tricky to figure out. I assume you are using hostmot2 you need to set the parameter hm2_5i20.0.gpio.NUMBER.invert_output true NUMBER must be the pin number for the pwm pin. look in dmesg for instance: pin 7 is pwmgen 0 's pwm pin [ 1141.053386] hm2/hm2_5i20.0: 72 I/O Pins used: [ 1141.053394] hm2/hm2_5i20.0: IO Pin 000 (P2-01): IOPort [ 1141.053397] hm2/hm2_5i20.0: IO Pin 001 (P2-03): IOPort [ 1141.053401] hm2/hm2_5i20.0: IO Pin 002 (P2-05): Encoder #0, pin B (Input) [ 1141.053405] hm2/hm2_5i20.0: IO Pin 003 (P2-07): Encoder #0, pin A (Input) [ 1141.053408] hm2/hm2_5i20.0: IO Pin 004 (P2-09): IOPort [ 1141.053411] hm2/hm2_5i20.0: IO Pin 005 (P2-11): Encoder #0, pin Index (Input) [ 1141.053415] hm2/hm2_5i20.0: IO Pin 006 (P2-13): IOPort -> [ 1141.053418] hm2/hm2_5i20.0: IO Pin 007 (P2-15): PWMGen #0, pin Out0 (PWM or Up) (Output) [ 1141.053422] hm2/hm2_5i20.0: IO Pin 008 (P2-17): IOPort [ 1141.053425] hm2/hm2_5i20.0: IO Pin 009 (P2-19): PWMGen #0, pin Out1 (Dir or Down) (Output) [ 1141.053429] hm2/hm2_5i20.0: IO Pin 010 (P2-21): IOPort [ 1141.053432] hm2/hm2_5i20.0: IO Pin 011 (P2-23): PWMGen #0, pin Not-Enable (Output) [ 1141.053589] hm2/hm2_5i20.0: IO Pin 060 (P4-25): StepGen #2, pin Step (Output) [ 1141.053593] hm2/hm2_5i20.0: IO Pin 061 (P4-27): StepGen #2, pin Direction (Output) [ 1141.053597] hm2/hm2_5i20.0: IO Pin 062 (P4-29): StepGen #2, pin (unused) (Output) [ 1141.053601] hm2/hm2_5i20.0: IO Pin 063 (P4-31): StepGen #2, pin (unused) (Output) [ 1141.053605] hm2/hm2_5i20.0: IO Pin 064 (P4-33): StepGen #2, pin (unused) (Output) [ 1141.053609] hm2/hm2_5i20.0: IO Pin 065 (P4-35): StepGen #2, pin (unused) (Output) [ 1141.053613] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort [ 1141.053616] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort [ 1141.053619] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort [ 1141.053621] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort [ 1141.053624] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort [ 1141.053627] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort [ 1141.053811] hm2/hm2_5i20.0: registered [ 1141.053815] hm2_5i20.0: initialized AnyIO board at 0000:02:02.0 so in your HAL file add: hm2_5i20.0.gpio.007.invert_output true and then your pwm should be inverted. I say should be cause I haven't tried it yet on pwm, but have for stepgen direction pins. Cheers Chris M |
| New Machine Build- spline mode nurbs mode | cooltool | CamSoft Products | 4 | 03-10-2009 02:03 AM |
| Mesa de agua | goyoasturias | Spanish CNCzone | 5 | 01-09-2009 01:06 PM |
| What is - Torque Mode? Position Mode? Speed/Velocity Mode? | sunmix | Servo Motors and Drives | 25 | 10-26-2008 03:53 AM |
| Mesa, AZ | john matthews | Mentors & Apprentice Locator | 1 | 08-24-2008 01:48 PM |
| Mesa 7i37 output wiring | 123CNC | LinuxCNC (formerly EMC2) | 3 | 03-05-2008 12:49 PM |
