Results 1 to 3 of 3
Thread: EMC won't recognize home on Y axis
    Mar 2009
    I have a 3 axis machine, with a bipolar Y axis. When I home all the axes, the X and Z will do the little back and forth dance. I can monitor the pins (thanks to PCW_Mesa) and see them go high and low.
    The problem comes in when I try to home the Y axis. Both steppers run the guides down to 0, hit the hall effect sensors, and stop. I can see the pin (12) for Y Home go high, but EMC doesn't seem to detect it. Instead, it just keeps "moving" the virtual cutting head and showing the position in the window as -6, -8, -12, etc.
    Does anyone have any ideas on how I can interrogate EMC at a lower level to see why it's not paying attention to this signal?
    Mar 2007
    Hi, yes, there are a number of ways to monitor any Hal pin. Hal meter, Hal scope, and configuration all in the machine menu. Or the Status display should show that as well. I find Hal scope probably the handiest because once it's set up, it remembers what you were looking at before rebooting EMC2. I hope that's what you were asking. Otherwise are the switches all on the same pin? Are all axis homing at the same time? The configuration files look all the same?
    Bill K.
    Registered pminmo's Avatar
    Jun 2003
    St. Peters, Mo USA
    You can post your configuration files here or go to linuxcnc.org and ask on IRC.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  1. Need Help!- G10 won't recognize B-axis (FANUC O-M)
    By CNC-John in forum Fanuc
    Last Post: 05-30-2009, 01:35 PM
  2. Anyone recognize this connector?
    By cnczoner in forum General Metal Working Machines
    Last Post: 09-09-2008, 10:34 PM
  3. SHW UF-2 & ISA 40 anybody recognize?
    By innova in forum General Metal Working Machines
    Last Post: 04-12-2007, 05:13 PM
  4. servos...how to recognize?
    By STUG in forum Servo Motors and Drives
    Last Post: 02-03-2005, 02:26 AM
  5. Can you recognize yourself?
    By ESjaavik in forum CNCzone Club House
    Last Post: 05-28-2004, 10:32 PM
