| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
| I'm currently have a big problem with EMC2 not reading a large G code file generated by art cam. i have try difference file extension from art cam and none of them work on EMC2. small file of 3000 line or so work just fine. i load one with 15000 line for a part that is 2"X2" and EMC2 load in fine. but it would not run the program, it don't even show the graphic of the part on screen. and when it show partial graphic of the part, the dimension show 18000" wide for a 2"x2" part. anyone having the same problem as i'm?????? HELP |
| Can you post some of the file? Can you cut the file down to a 1000 lines and load that? I've loaded some large files in emc without issue.
__________________ Check out some of my vids: http://www.youtube.com/user/blauschuh |
if i cut the file down to 1000 line, it would work fine. the problem is that i want to make a small jello and cookie mold and need to run all the code at once. separating it would take a lot of time and would not be accurate. i have attach a file of what I'm trying to run on emc2 . you can download it and see if it run on your emc2 or not. """"" i try to attach a file, but i don't know where it when to. here is my email, if you want a copy the G code file. gonowvdo123@yahoo.com"""" |
| How much RAM memory do you have in the computer? ZIP the file and attach it.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| Loaded fine for me, over 16xxx lines of gcode. 1.6G Atom, 1GB ram.
| Good catch kweierbach! I thought he was just having a load problem. Just looking through the code it does look absolute.
| Tags |
| emc2, help a newbie, newbie |
| Need Help!- Using Gedit without EMC2 to manually edit Gcode with syntax | mouratoglou | LinuxCNC (formerly EMC2) | 6 | 07-25-2009 02:36 AM |
| Large File? | esadaddy | Fanuc | 18 | 01-15-2009 11:46 PM |
| Solidworks to EMC2 Compatible GCode? | leeleatherwood | LinuxCNC (formerly EMC2) | 9 | 10-18-2007 03:43 PM |
| EMC2 gcode O-words and parameters | acondit | NCPlot G-Code editor / backplotter | 2 | 07-13-2007 09:47 AM |
| Reading a Graphics File in VB 2005 | GaryM | Visual Basic | 5 | 06-23-2007 11:51 PM |
