| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I'm trying to run some g code in axis with all power to the machine cut off. Axis seems to have an issue when it hits the first G0 jog command and spits out a "joint 0 error" and then stops. My settings for jog speed are 31in/min, feed override arbitrarily set to 78% it that matters. Each time it fails with Vel: 146.1600, Vel: 203.0472, or some other high number in the axis window. Why such a high number? Jog is set to 31in/min in the slider bar. I changed the G0 line 3 times each time limiting the move to one less axis, and it continued to fail. Prior to each run I zeroed out x,y,z. It's another data point if nothing else. 1st run fails: G0 X0.992 Y1.008 Z0.15 2nd run fails: G0 X0.992 Y1.008 3rd run fails: G0 X0.992 If I comment out the G0 line, all 15000 lines in the program run without issue (all G1 commands). Changing the first G0 to a G1 and slapping a feed rate of F5 on the end solves the problem. |
| Yes, I disabled everything but the output signals for the X, Y, and Z axis. |
| MIN_FERROR = 0.01 MIN_LIMIT = -20.0 # Generated by stepconf at Sun Aug 23 22:49:50 2009 # If you make changes to this file, they will be # overwritten when you run stepconf again [EMC] MACHINE = 2axistest NML_FILE = emc.nml DEBUG = 0 [DISPLAY] DISPLAY = axis POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 1.2 INTRO_GRAPHIC = emc2.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/scott/emc2/nc_files INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = emc.var [EMCMOT] EMCMOT = motmod SHMEM_KEY = 111 COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 BASE_PERIOD = 39000 SERVO_PERIOD = 1000000 [HAL] HALFILE = 2axistest.hal HALFILE = custom.hal POSTGUI_HALFILE = custom_postgui.hal [TRAJ] AXES = 3 COORDINATES = X Y Z LINEAR_UNITS = inch ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 1.50 MAX_LINEAR_VELOCITY = 15.00 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl [AXIS_0] TYPE = LINEAR HOME = 0.0 MAX_VELOCITY = 6.5 MAX_ACCELERATION = 28.0 STEPGEN_MAXACCEL = 29.4 SCALE = 15240.0 FERROR = 0.05 MIN_FERROR = 0.01 MIN_LIMIT = -20.0 MAX_LIMIT = 20.0 HOME_OFFSET = 0.0 [AXIS_1] TYPE = LINEAR HOME = 0.0 MAX_VELOCITY = 15.0 MAX_ACCELERATION = 24.0 STEPGEN_MAXACCEL = 25.2 SCALE = 1587.5 FERROR = 0.05 MIN_FERROR = 0.01 MIN_LIMIT = -4.0 MAX_LIMIT = 4.0 HOME_OFFSET = 0.0 [AXIS_2] TYPE = LINEAR HOME = 0.0 MAX_VELOCITY = 6.41025641026 MAX_ACCELERATION = 30.0 STEPGEN_MAXACCEL = 31.5 SCALE = 4000.0 FERROR = 0.05 MIN_FERROR = 0.01 MIN_LIMIT = -2.0 MAX_LIMIT = 3.0 HOME_OFFSET = 0.0 STEPCONF file: cant post it... xml issue maybe? Last edited by margni74; 08-30-2009 at 10:39 AM. Reason: stepconf issue: posting xml seems to screw up the post |
| I bet it is a stepgen headroom issue. Increase the STEPGEN_MAXACCEL to be a good 20 - 30% over your MAX_ACCELERATION So [AXIS_0] . . . MAX_ACCELERATION = 28.0 STEPGEN_MAXACCEL = 29.4 should be MAX_ACCELERATION = 28.0 STEPGEN_MAXACCEL = 36.4 |
| your scale for axis 0 looks odd to me. It is a product of number of motor steps, microsteps, pulley teeth and leadscrew (TPI for imperial, pitch for metric). Its very different from the other axis, is that right. your max velocity for axis 1 is 900 inches a minute is that right? Post your stepconf file on filebin.ca Chris M |
Ill double check the number thanks for the help guys. |
| I also see the MAX_LINEAR_VELOCITY = 15 (This controls max velocity) it is in units per second, your units are inches so 15 inches per second 15 X 60 seconds = 900 inches per minute. Also Jog speed slider won't affect G0 moves. Max Velocity slider will affect G0 moves. Chris M |
#10
| And to all this, we had the same error on a step motor machine. After disconnecting the limit switches it ran fine. The switch cables weren't shielded and it caused faulty signals. |
| Hawk Claw Joint | spalm | WoodWorking | 1 | 10-20-2009 02:19 PM |
| Joint following error | Gads | LinuxCNC (formerly EMC2) | 3 | 04-11-2008 09:02 AM |
| joint venture in China | JennyYin | Product Announcements & Manufacturer News | 0 | 11-06-2006 02:21 AM |
| help with screw joint in cosmosmotion | posix | Solidworks | 1 | 01-17-2006 05:40 AM |
| Intersting robotic joint | Zathras | Mechanical Calculations/Engineering Design | 9 | 10-07-2005 01:05 PM |
