Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 08-25-2009, 07:15 PM
ibuildstuff4u is on a distinguished road
Quick EMC Question.
Can you run EMC on a Mac computer? I love my Mac and would love to have one in the shop instead of the windows computer I'm using now.
Thanks for the help!
Dale P.
Old 08-25-2009, 08:16 PM
acondit's Avatar
acondit is on a distinguished road
Not yet. I tried running Ubuntu under Parallels and Ubuntu runs OK but emc2 crashes.
Alan
http://www.alansmachineworks.com
Old 08-25-2009, 08:24 PM
Bummer, my main computer is a mac and have to do all of programing down stairs in the shop. It would be nice to do the programing in the office and then transfer the file to the shop.
Thanks for the reply.
Dale P.
Old 08-25-2009, 09:48 PM
jmelson is on a distinguished road
Dale P.
EMC requires a real time version of Linux. I don't think anyone has gotten an RT patched kernel on the Mac, but I could be wrong. Running any RT environment in a virtual machine is definitely NOT going to work well. Also, most of the motion control hardware requires either a parallel port or a PCI slot, neither of which are present on most Macs. You could run a split system, with Axis running on the Mac, and the motion control, interpreter, etc. running on the PC. This is now supposed to be fairly well documented in the EMC user's guide, I think.
Jon
Old 08-26-2009, 02:51 AM
svenakela is on a distinguished road
Jon
A RT environment will not work at all in a virtual machine (and not on laptops either, by the way). But if you only need an EMC2 simulator on your office Mac you can probably run it in a VM. Then you don't need the real time patched kernel.
http://wiki.linuxcnc.org/cgi-bin/emc...Pure_Simulator
And if you follow the link in the bottom (Compiling/installing EMC2) you will find another link to a guide I wrote how to setup the simulator in 9.0.4 (chapter 5.4: http://article.gmane.org/gmane.linux...emc.user/15617).
Regards,
Sven
Old 09-02-2009, 12:27 PM
roamingdrone is on a distinguished road
Don't forget, that EMC2, at least the AXIS interface, is an X windows application. It can display on any X server. That means you can install an X server for Mac (Hummingbird Xceed is one that I used to use, IIRC) - and then set your display on your linux shell to be the remote address of your mac box running the X server.
Voila - you can now run EMC2 on your Mac, but it's really running on the Linux box downstairs =)
!c
Old 09-04-2009, 09:15 AM
linuxstep1 is on a distinguished road
EMC2 always needs Linux with RTAI real time extension, but the UI can use a remote X-window system, and run on any computer which supports remote X-Window . Here is a link how to do that for MS windows (in german):http://www.cncecke.de/forum/showthread.php?t=45303
I guess its similar for MAC.
BTW: EMC2 runs fine on my old Dell Latitude laptop with 15 usec latency, after applying the SMI patch http://wiki.linuxcnc.org/cgi-bin/emc...ixingSMIIssues Without the patch, latency was 1.1 msec.
regards, Gerd
Old 09-04-2009, 10:07 AM
acondit's Avatar
I don't know about anyone else, but my goal is to just run emc2 on my macmini in my office so that I can proof gcode in Axis (without having to fire up the boxes out in the shop). I am not trying at this point to control the machines.
Alan
Old 09-04-2009, 10:48 AM
Alan
You should be able to run it in simulated mode then. Otherwise, you can still proof it remotely from the linux box by pointing it to a local X server on the mac. You don't need to actually control the machine, can run simulated on the linux box, but with the UI displayed on your mac.
!c
Old 09-04-2009, 12:03 PM
In any case you need a linux box, to run EMC, also in simulation mode, without a machine. AFAIK no way around.
  #11   Ban this user!
Old 09-04-2009, 12:42 PM
acondit's Avatar
I have Linux running on my Mac, it just won't support RTAI under Parallels. So the question for me is does it run in sim mode without RTAI.
Alan
  #12   Ban this user!
Old 09-04-2009, 12:59 PM
see links in Svens post below. Could be you can install a simulator without RTAI.
regards, Gerd
Quick Little question Clawsie Machine Mastercam 3 01-08-2008 06:20 PM
Quick Tig Question Edster Welding, Brazing, Soldering, Sealing 5 08-15-2005 08:19 PM
really quick question: bigal General Electronics Discussion 1 06-21-2005 07:39 PM
A quick question? Bartman Solidworks 4 05-30-2005 09:24 PM
Quick V18 Question Edster BobCad-Cam 3 12-13-2004 09:53 AM
