Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 08-24-2009, 08:25 AM
jshroff is on a distinguished road
EMC2 Stepconf - does test axis dialog monitor the limit switches?
Hi All,
I am trying to configure EMC2 for a homebuilt CNC router and have managed to get all the three axis working under EMC2, now I am trying to ensure my limit switches are working.
I have setup a limit switch for each axis and plan on using that as a home + limit switch.
My question - when I click on test axis within the stepconf program and step an axis would manually triggering the limit switch stop the stepping? I have been testing and it appears that the test axis dialog ignores the limit switch and continues moving is that the case?
Jay
Old 08-24-2009, 09:46 AM
acondit's Avatar
acondit is on a distinguished road
I think you are correct. I don't believe stepconf monitors the limits at all. It is designed to test the stepper motors and the setup values for them. The rest of the things that stepconf allows you to set up must be tested in emc2 (limits, spindle control, charge pump, etc.).
Alan
http://www.alansmachineworks.com
Old 08-24-2009, 09:35 PM
chester88 is on a distinguished road
Stepconf tests ignore the limit / home switches. As Alan said you'll know pretty quick when starting EMC if they work.
Old 08-25-2009, 09:23 AM
Alan, Chester88
Thanks for the confirmation. I ran EMC2 and confirmed the limit switches are working so like you mentioned the stepconf ignores the limit switches.
Now to get the proper directions configured for all the axis and I should be all set.
Jay
EMC2 Stepconf - Table Travel - Units used? skimask LinuxCNC (formerly EMC2) 7 01-13-2009 04:38 PM
emc2 can't test x axis me2cyclops LinuxCNC (formerly EMC2) 5 05-27-2008 11:28 AM
EMC2 & Limit Switches acondit LinuxCNC (formerly EMC2) 12 07-20-2007 12:23 PM
EMC2 & Limit Switches pcstru LinuxCNC (formerly EMC2) 0 10-19-2006 11:10 AM
Limit switches for XYZ axis scheek General Electronics Discussion 2 09-07-2006 07:33 AM
