Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 08-16-2009, 07:06 AM
Claudiosd is on a distinguished road
i have a problem
i have this problem. Can you help me?
Old 08-16-2009, 10:57 AM
dave3431 is on a distinguished road
you need to home all of the axis X,Y & Z.
Old 08-16-2009, 12:07 PM
thanks. Now, i have this problems. i don't know how to configure the emc2.
I just set the stepping motors, but the other I put in the unused pins
Old 08-16-2009, 12:09 PM
Why set limits?
Old 08-16-2009, 05:47 PM
chester88 is on a distinguished road
That message means you would exceed the software limits.
Limits are designed to stop the axis movement before it gets to end of physical travel.
There are hardware limits and software limits.
Hardware limits are what you connect to switches.
software limits are based from home location and table travel.
(I am assuming you used stepconf to make the configuration)
read this:
http://www.linuxcnc.org/docs/2.3/htm...is-Travel-Home
Soft limits, while annoying to set up in the beginning is designed to stop crashes and tells you if the program you are running has asked EMC to move an axis beyond the physical travel before it actually moves the axis.
Old 08-16-2009, 06:33 PM
Thank you very much for your help.
then I would be using soft limits, and my problem is not set.
Can it be that the parameters I have to configure are these?
Old 08-16-2009, 10:06 PM
yes set the home switch location to zero as you don't have home switches.
Then with home position set at zero and table travel set to -4 and 4
you would need to move the axis to the middle of travel and home, as 0 is half way between -4 and 4.
I'm pretty sure that is how this works. I use home switches.
bottom line is you have to home in the right position for soft limits to work.
Old 08-17-2009, 12:44 PM
thanks.that was the problem.
I never knew either micorpasos and set the leadscrew pitch. Can someone help me?
is obtained as the leadscrew pitch and microsteps?.
to calculate the leadscrew pitch 1/tpi use. this is right?
Old 08-17-2009, 12:55 PM
pminmo's Avatar
pminmo is on a distinguished road
Are you using stepconf to setup your needs? It asks pitch and microstepping seperately.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 08-17-2009, 04:13 PM
yes, i'm using stepconf.
relationship between motor and leadscrew is (1:1).
I think the pitch is calculated:
p = 1/tpi
and this value must be re-divide it by one to calculate rev / inch:
rev / inch = 1 / p
This is true, or wrong?
microsteps not know anything about me and I needed to explain a little about this.
  #11   Ban this user!
Old 08-17-2009, 06:00 PM
pminmo's Avatar
p = 1/tpi
rev / inch = 1 / p
p=1/tpi.....IF it is a single start screw.
  #12   Ban this user!
Old 08-17-2009, 06:50 PM
I'm using single start screw.I use two formulas to explain the above?.
or just p = 1/tpi?
machine problem or software problem? bcnc Syil Products 8 10-26-2009 09:51 AM
