| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I am new to EMC and am trying to get all the terminology straight. From my reading it seems like there are two ways to go when implementing a system. please correct me if I am wrong. The first method is to use the parallel port on the back of the computer, where the printer would plug in. The second method is to use a pci type card. One would have to take off the cover of the computer and plug the card in where a modem or graphics card would go. I am planning a "big iron" project, and am not sure how to proceed. I have fanuc 20 amp 146 volt ac brushless motors. I do not have servo amplifiers yet and could probably get by with less than the full rated torque. It won't have a tool changer to start, but will eventually. Which way is better? Can both be used simultaneously ? |
| What a standard parallel port really won't handle is high count encoders being read in software. The computers just aren't fast enough. I would suggest a Mesa 5I20 pci card. It has plenty of IO and will handle the encoder reading in hardware. The parallel port on the back of the computer is fine for smaller systems and can even be used for larger systems with something like the Mesa 7I43. The 7I43 is a lot like an external 5I20 (accessed via a parallel port instead of the pci bus). Alan
__________________ http://www.alansmachineworks.com |
| Thanks for the response. I see where the 5i20 plugs in to the computer. It has what look like three 50 pin ribbon cable connectors. Does the pwm signal come out of the 5i20 and go directly into the servo amplifier, or is there something in between? I realize that If I choose a servo amplifier that only accepts analog +- 10 volt command signal I will then need some kind of adapter/converter. What is FGPA? The encoders have 2000 pulses. |
Alan
If you use Mesa 7i33 daughter boards, it will convert 4 channels of 5i20 pwm to +10V analog servo control signal. There are also USB and parallel port variant, Mesa options continue to grow. You may want to carefully peruse all their hardware and capabilities. Peter will help you out should you run in to some technical difficulties. I would say I'm a fan. |
The advantage of this is that you don't need to put anything inside the computer, and it may simplify the wiring. Oh, Fanuc motors? Red cap? You should know that the standard Fanuc "red cap" motor with the "pulse coder" encoder are proprietary, and normally can't be used with industry compatible servo drives. I now have a converter board that allows you to use these red cap motors with industry compatible drives, as well as my own brushless drives. You can see these items at http://jelinux.pico-systems.com/oscr...alog/index.php Jon |
| PCI Parallel Port Card | Adamj12b | Mach Software (ArtSoft software) | 36 | 12-22-2008 09:03 PM |
| Cheap parallel port card | fahque99 | Mach Software (ArtSoft software) | 0 | 11-23-2008 07:07 PM |
| Mister versus flood versus ??? coolant system | split63 | Bridgeport and Hardinge Mills | 14 | 10-02-2006 05:18 AM |
| pcmcia parallel port card ? | WsW-WYATT | Machine Problems, Solutions , Wireless DNC, serial port | 8 | 09-07-2005 06:29 AM |
| Servo driver system for parallel port indexers | imserv | Product Announcements & Manufacturer News | 0 | 07-22-2005 12:26 PM |
