| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
| Hi CNC Community - Great Forum - I'm new to posting here & newish to CNC (so please treat me gently !!) I have acquired a Defiance CNC machine as a project, which is in great mechanical condition, but the control side is not working. The machine was probably one of the last before Defiance went under, and I understand it has never run for long without issues and has always been unstable (hence the condition). I've managed to get all almost everything - spindle and tables to work, it just will not get past the initial toolchange homing sequence no matter how hard I try. All the sensors on the changer mechanism are working and trace back to the board OK, so my ignorant guess is that the PMAC program is a bit messed up, and I really do not want to try to understand the Delta Tau PMAC, it looks way too complicated for my brain capacity. Anyway, as a project, and a steep learning curve, I intend to enjoy the coming winter months in an attempt to run it under EMC2 from a PC and retire the old on-board computer, DOS based Evolution software and PMAC, but keep everything as is from the opto board outwards. The servos and controllers are all yaskawa, the spindle invertor is Saftronics. The encoders are on the leadscrews. There are a load more I/O connections, but they are all fairly logically put together and understandable. SO, sorry for the preamble, but the real question is what is the best interface board between the PC and the machine with EMC2 for me to play with ? Has anyone got any similar retrofit experience, or bad or good experience or recommendations on matching motion control boards with EMC2 for servos ? Cheers Bill |
| I would join the emc2 mailing list. https://lists.sourceforge.net/lists/listinfo/emc-users They have some very helpful people there. Some of them are involved in the development of electronics to interface. I have found them to be very helpful. Mike |
| If your servo are +/- 10 volt then you will need something like the Mesa 5I20 with the 7I33 Servo interface card. WWW.mesanet.com |
| [QUOTE=DonnieET;644308]If your servo are +/- 10 volt then you will need something like the Mesa 5I20 with the 7I33 Servo interface card. Thanks DonnieET I checked the specs of the servo controllers - it gives +-10v for the reference voltages for the speed and torque. Is that what your +/- refers to ? |
| Personaly I would get the Delta Tau working. But then I know Delta Tau and do not know EMC2 Answer to you question. 99% chance you Servo drives are +/-10V input either torque or velocity mode. There is Encoder feed back into the PMAC card. Depending on the drives it might go through them or not. Usaly the PMAC does all of the tuning of motors and the servo drive is just an amplifer. The Acc34AA is prproprietary Delta Tau board. It is just an I/O board that talks to the PMAC card. Take it off and put on Ebay with rest of the PMAC parts. You need to replace this with some other I/O. I would replace it with Opto22 I/O. Some questions What modle Yaskawa drives & motors? You should be able to look up all the spec's. Is there an encoder on the motor and one on the leadscrew? |
#10
| You really have to keep the drives, the SGMP motors use a proprietary commutation scheme encoded into the encoder's index track. The drives produce a decoded ABZ signal that you can feed to your servo interface. Jon |
| Place to have control boards repaired? | cjdavis618 | Mori Mills | 6 | 12-09-2008 02:39 PM |
| Where can I buy the boards for the Control Crusader II? | blmachado | General Electronics Discussion | 3 | 04-16-2007 03:59 PM |
| stepper control boards and their functions | cyclotron | DIY-CNC Router Table Machines | 3 | 03-02-2007 11:39 PM |
| Need advice on milling circuit boards | Bill Davis | Stepper Motors and Drives | 13 | 04-06-2006 07:13 AM |
| Printer control boards for CNC???? | thuffner3 | General Electronics Discussion | 7 | 07-03-2005 07:09 PM |
