Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 07-19-2009, 08:33 PM
Zig Zig is offline
Zig is on a distinguished road
File property under Axis- machining time estimate
I have been a happy user of EMC2 for some months now and in general am very happy with the utility EMC2 and Axis offer.
There is one feature of Axis I am not quite sure how to interpret; namely in file properties Axis provides the ngc file summary providing statistics such as idle traverse and cut length as well as time taken ( presumablu to cut the path).
This Axis estimated time to cut the path seems to be a gross under estimate ( at least on my machine) of the actual machining time.
Is there some parameter i need to set/reset/ignor/unignore in order to attain a better estimate of actual machining time?
Old 07-25-2009, 11:40 AM
atex57 is on a distinguished road
An earlier version had a problem with time estimates. What version are you running? I am at 2.2.8 and it seems to be fine on my simple programs. Ed.
Old 07-25-2009, 05:35 PM
Zig Zig is offline
Hello Ed,
Thanks for Your comments.
Typically my jobs run for about an hour or so and the estimates are always much lower than the actual machine time.
I guess the smaller the job the less aparent the discrepancy becomes.
Old 07-25-2009, 06:01 PM
Well, some of my programs may run for 3 hours as it may have 60-80 loops to run through. What version are you running? Ed.
Old 07-25-2009, 06:05 PM
Zig Zig is offline
I too am runing with 2.2.8
Please take a note of what the EMC file property tells you and compare that to the actual duration of machining.
I would be interested to hear of Your experience.
I shall post the same stats on my next job for completeness.
Old 07-28-2009, 03:31 AM
Zig Zig is offline
The most recent exaqmple of the time estimation...
FILE >PROPERTIES> time to run 37 seconds
Actual machining time 30 minutes
There must be some assumptions made by the gurus which escape me that a piece of software which in general behaves so well should undrshoot the mark so badly in this one instance
Old 07-31-2009, 08:14 AM
Are your programs written with a CAM system? Just guessing here but if they are written with a zillion short moves to make a radius it could be a problem with acceleration rates to start and stop each line. Do a search the Wiki on linuxcnc.org for, I believe, G64.* to smooth out short moves. Ed.
Old 07-31-2009, 04:44 PM
Zig Zig is offline
My work is in PCB milling and the files are full of g02 g03 code.
And yes plenty of short strokes but even so the estimates ought to be unaffected by the file content.
As for blending, there is not much room for blending whenfeatures being milled are of the same order of magnitude as the blending settings.
For an example of work
http://www.cnczone.com/forums/showth...0&goto=newpost
According to Big John the estimation is only an approximation and might get confused by too many Z moves.
Need Help!- V23 run time estimate? cut more BobCad-Cam 7 05-08-2009 01:40 PM
Beta Run time estimate barbter NCPlot G-Code editor / backplotter 1 05-30-2008 06:31 AM
IH plans and intellectual property Runner4404spd Industrial Hobbies (Support forum) 20 12-15-2006 06:38 AM
dry run's time estimate ? lepton TurboCNC 1 07-02-2006 06:02 PM
operation time estimate in setup sheet ? andy55 Mastercam 3 10-06-2005 12:14 PM
