| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
#25
| OK let's Bump this thread. I am currently running turbocnc, definetly adequate, but I am a Linux Junkie, and want the networking and all the Linux goodies like editing and filtering to work my cnc files. I just did a Deskart run that was 4+ meg and transfered it via 4 floppies to my turbocnc box. painful to say the least, It would have been aneasy transfer with a Linux box. I hate windows basicly. To damn flacky for me. I have a Xylotex controller on a taig mill, anyone done this combination with EMC? |
#26
| You do know that you can do networking in DOS? It's pretty easy to set up. http://www.dendarii.co.uk/FAQs/dos-net.html
__________________ Nathan |
#27
| Yeah but it is a pain and what will it do to the real time charecteristics of DOS. THe turboCNC manual recommends no TSR types of stuff loaded in the config.sys or autoexec.bat, not even DOSKEY! Where a good real time kernel in Linux will set the proper priority to the task and can interupt the kernel as needed. |
#28
| Do the newer BDI-live distro's support intergrated graphics Mobo's? I have downloaded BDI, BDITNG and BDI Live and tried at least five diffented revision's over the last few years, on two different motherboards and three different graphics cards with no success. A SIS 645 chipset Athlon board, an IBM PIII-800 business box with Intel chipset and intergrated graphics, ATI Expert 2000 or an older PCI matrox graphic card. The furthest I ever got was with one of the BDI-Live CD's where it got into the reading a zillion files part before locking up on the business box with the matrox card. In comparision TurboCNC is a real no brainer. Dos is kind of nice. Switch on machine wait ten seconds, start machining. Finish machining, close TCNC kill computor with button on front. Microsofts last stable OS. Since I have a lathe anyway TurboCNC is a good choice, but for my up-coming mill, that CVC and CutterRadiusComp in EMC is tempting.
__________________ Regards, Mark www.wrathall.com |
#31
#32
| Dieguy check this link for xylotex and emc: http://wiki.linuxcnc.org/cgi-bin/emc...l?XylotexBoard I would suggest to use the radio shack method, you'll understand once you read the material RotarySMP You might want to check the archives at: http://sourceforge.net/mailarchive/f...orum=emc-users or send an email to the list, also there is an irc channel jerry |
#33
Now has anyone played with EMC2. The compliation should not be a problem. Getting the Real time linux might be an issue. I will post back this weekend after I "fix up" the current controller PC with a hard drive and CDROM. It works A-OK with turboCNC but DOS is so featureless. I bet an AMD XP2400 should be adequate. |
#34
I have installed 3 versions of the BDI (Brain Dead Installs) With Varying degrees of success. Mostly due to the lack of updated Driver support and my own lacking of knowledge of how the “Make” utility works. The Debian based version seems to be the most forgiving as far as hardware is concerned but the Morfix BDI lite is would appear to be perfect for those of us not yet good enough at Linux to give up our MS dope just yet. The Debian version comes with QCAD for doing 2d basic CAD stuff. Both of these versions have an option for installing in the free space on your current HD And I believe it will allow you to create a disk to boot to if you wanted a duel boot system. The Red Hat 6 ver. of the BDI didn’t run to well on my test computer (video card support). We are looking at developing a line of small scale Gantry Tables using the EMC stuff so feel free to send me any wish list type items that would make your lives easier. |
#35
| So someone waked up this thread again. You should try out Pico-systems.com Universal Stepper Board. Since my last post above, I installed it here on a EMC BDI RC46. It is just unbelievable how much smoother my steppers runs now! I can now run as fast as my drives/motors will allow. No coarse running as with freqmod. I'm now up to around 3500mm/min compared to 500mm/min before. And the limit is that I have only 70V to feed the motors, not the ability to emit equally spaced step pulses. As the pulses are generated in hardware, there is no skew or jitter on the pulse train. This works so well I have now mothballed my plans to change to servos. I can no longer see any need for that. Disclaimer: I have no connection with Pico-Systems other than being a very happy customer. |
| Engraving Software | The Wizard | General CAM Discussion | 31 | 03-29-2005 05:38 AM |
| Software sales or "license transfers" | metlmunchr | BobCad-Cam | 3 | 07-05-2004 04:47 PM |
| ***One stop CNC software guide*** | ynneb | DIY-CNC Router Table Machines | 4 | 05-27-2004 04:31 PM |
