| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
the gecko setup in emc configuration generally has a step time :4000 step space :500 Direction hold :20000 direction setup : 1000 just a question of if its the same for the g540 and its smaller drives. |
| the only reason i ask is i have been having some missed steps and EMC suggests checking the step driver settings. if anyone knows its correct i'd be happy to hear it. on other thing i'm hung up on, is the explanation emc gives in the 'setting up your base period' section of the manual. where it confuses the hell out of me with a long winded example of lowering the base period for gecko drives. does any one understand how your suppost to change the 'dir hold' to 2 when it is already 20,000. i can open the ini file an all but it is confusing. |
| The section your talking about was taken from this wiki writeup: http://wiki.linuxcnc.org/cgi-bin/emc...StepGeneration I'm not sure if the stepgen was changed from using multiples of base period to using time in nanoseconds or the original text was wrong, bu the man page says that stepgen requires time in nanosecond. In a terminal type 'man stepgen' to read that. |
| re-reading the write-up i can't for the life of me work out were he gets those numbers and the fact that to gecko drivers 202 and 203 have different frequencies leads me to believe i have been using the wrong driver settings. i've heard(and read on gecko site ) the g540 and its 250's are little 201's ,does that reffer to the frequencies used, i suppose. |
| The manual for the 250 says the step time is 1000 ns minimum. It doesn't says anything about the rest. Maybe you could ask on another cnczone thread. Gecko is represented here somewhere... Either that or just try some different settings and see what works. |
| This is a .stepconf that you can open in the step config wizard. It was setup by one of the emc developers. He would like some feedback. http://www.linuxcnc.org/wiki/uploads/G540.stepconf sam |
#10
| If you look at that config (just given) then timing is 1000 for steplength, stepspace, dirhold, and dirsetup. That sounds like a good place to start. The timing is not the same as the 201 or 202 . Further more your first post says you used steplendth as 4000 and step space as 500 - according to the EMC wiki that should be the other way around (but that is for the 201, 202, 210 or 212 anyways) |
#11
| ok, i don't have my machine with me,but when i get home i'll look into that. if thats the case the g540 is a much better driver than i thought and it explains my unfortunate first few attempts. i first started in the deep end trying to route out a foam shell that ended up being right out of square. hense this thread with me trying to find out whats wrong. the figures i gave earlier were straight out of my version of EMC stepconfig.if they don't match the 201 then go figure. any way i'll be glad to see my new ballscrew design can pull higher speed. |
| Newbie- ZAY7045 + Gecko G540? | clocker | Benchtop Machines | 42 | 01-13-2010 08:48 PM |
| Gecko G250s VS. G540 | noisillator | Taig Mills & Lathes | 7 | 06-24-2009 01:06 AM |
| Need Help!- Gecko G540 | rotger | Servo Motors and Drives | 0 | 06-02-2009 12:43 PM |
| gecko g540 | Teyber12 | Benchtop Machines | 3 | 05-31-2009 02:23 PM |
| Setting up the G540 | boxwood | Gecko Drives | 4 | 09-15-2008 12:44 PM |
