06-24-2009, 11:09 AM
I'm trying to update emc2 2.2.8 to 2.3.x on Ubuntu 8.04 Hardy heron
If I run emc2-install.sh fails - suggesting 'manually run dpkg' scrolling up the terminal windows show a failure at the beginning of the script - sudo unable to resolve host Axis [Axis is the name of the machine]
I'm very much a linux newbie (and to be honest, I hate its cryptic processes) so please be patient. Code: bill@Axis:~$ '/home/bill/Desktop/emc2-install.sh'
sudo: unable to resolve host Axisgpg: requesting key 8F374FEF from hkp server pgpkeys.mit.edu
gpg: key 8F374FEF: "EMC Archive Signing Key " not changed
gpg: Total number processed: 1
gpg: unchanged: 1
OK
Hit http://security.ubuntu.com hardy-security Release.gpg
Ign http://security.ubuntu.com hardy-security/main Translation-en_GB
Ign http://security.ubuntu.com hardy-security/restricted Translation-en_GB
Hit http://gb.archive.ubuntu.com hardy Release.gpg
Hit http://gb.archive.ubuntu.com hardy/main Translation-en_GB
Hit http://gb.archive.ubuntu.com hardy/restricted Translation-en_GB
Ign http://security.ubuntu.com hardy-security/universe Translation-en_GB
Ign http://security.ubuntu.com hardy-security/multiverse Translation-en_GB
Hit http://gb.archive.ubuntu.com hardy/universe Translation-en_GB
Hit http://gb.archive.ubuntu.com hardy/multiverse Translation-en_GB
Hit http://gb.archive.ubuntu.com hardy-updates Release.gpg
Ign http://gb.archive.ubuntu.com hardy-updates/main Translation-en_GB
Ign http://gb.archive.ubuntu.com hardy-updates/restricted Translation-en_GB
Ign http://gb.archive.ubuntu.com hardy-updates/universe Translation-en_GB
Ign http://gb.archive.ubuntu.com hardy-updates/multiverse Translation-en_GB
Hit http://security.ubuntu.com hardy-security/main Packages
Hit http://security.ubuntu.com hardy-security/restricted Packages
Hit http://security.ubuntu.com hardy-security/main Sources
Hit http://security.ubuntu.com hardy-security/restricted Sources
Hit http://security.ubuntu.com hardy-security/universe Packages
Hit http://gb.archive.ubuntu.com hardy/main Packages
Hit http://security.ubuntu.com hardy-security/universe Sources
Hit http://security.ubuntu.com hardy-security/multiverse Packages
Hit http://security.ubuntu.com hardy-security/multiverse Sources
Hit http://gb.archive.ubuntu.com hardy/restricted Packages
Hit http://gb.archive.ubuntu.com hardy/main Sources
Hit http://gb.archive.ubuntu.com hardy/restricted Sources
Hit http://gb.archive.ubuntu.com hardy/universe Packages
Hit http://gb.archive.ubuntu.com hardy/universe Sources
Hit http://gb.archive.ubuntu.com hardy/multiverse Packages
Hit http://gb.archive.ubuntu.com hardy/multiverse Sources
Hit http://gb.archive.ubuntu.com hardy-updates/main Packages
Hit http://gb.archive.ubuntu.com hardy-updates/restricted Packages
Hit http://gb.archive.ubuntu.com hardy-updates/main Sources
Hit http://gb.archive.ubuntu.com hardy-updates/restricted Sources
Hit http://gb.archive.ubuntu.com hardy-updates/universe Packages
Hit http://gb.archive.ubuntu.com hardy-updates/universe Sources
Hit http://gb.archive.ubuntu.com hardy-updates/multiverse Packages
Hit http://gb.archive.ubuntu.com hardy-updates/multiverse Sources
Hit http://www.linuxcnc.org hardy Release.gpg
Ign http://www.linuxcnc.org hardy/base Translation-en_GB
Ign http://www.linuxcnc.org hardy/emc2.2 Translation-en_GB
Ign http://www.linuxcnc.org hardy/base Packages
Ign http://www.linuxcnc.org hardy/emc2.2 Packages
Ign http://www.linuxcnc.org hardy/base Sources
Ign http://www.linuxcnc.org hardy/emc2.2 Sources
Hit http://www.linuxcnc.org hardy/base Packages
Hit http://www.linuxcnc.org hardy/emc2.2 Packages
Hit http://www.linuxcnc.org hardy/base Sources
Hit http://www.linuxcnc.org hardy/emc2.2 Sources
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
bill@Axis:~$
__________________ Bill |
