Results 1 to 7 of 7
Thread: Using Gedit without EMC2 to manually edit Gcode with syntax
    Jun 2009
    ARGENTINA
    Red face Using Gedit without EMC2 to manually edit Gcode with syntax
    Hello, i want to ask you about this, im a newby
    http://wiki.linuxcnc.org/cgi-bin/emc...Creating_Gcode
    here i found that gedit can be used to edit g code with EMC2
    thats why i post my question here, because i need to extract the gedit g-code syntax script add on from EMC2 but I cant install it because my PC its too old to run EMC2...
    I only need the G-code editor, to manually write the G-code in Gedit.
    Please, can anyone help me to figure out this???
    thank you very much
    Registered acondit's Avatar
    Apr 2005
    Gedit is just a text editor with a gui interface ( part of the Gnome gui interface package ). Any text editor will work.
    Alan
    Jun 2009
    ARGENTINA
    I know that gedit its a simple text editor.
    The situation is the following:
    We write the code manually using NCLink notepad (we dont use this prorgram to send code trough serial cable) ONLY to write it...
    Its easier to write the G code with this notepad as it marks the syntax with colours.
    The problem is im moving to LInux and I cant find a replacement, NClink doesnt work under Linux with Wine...
    Can anyone suggest me a replacement that has this feature of the G code syntax???
    Apr 2005
    I am not aware of any syntax aware gcode editors. Maybe someone else can help.
    Alan
    Nov 2005
    Jun 2009
    ARGENTINA
    thans man, i think that with the link about highlighting in gedit ( http://wiki.linuxcnc.org/cgi-bin/emc...hting_In_Gedit ) i found something quite useful to configure gedit to edit gcode without installing the complete EMC2 aplication as I dont need it. Let me make some tests and I tell you if those indications work.
    If anyone knows another solution for editing g code in Linux with a syntax indicator colouring the code please share the knowledge...
    thanks a lot
    Mouratoglou
    Feb 2004
    Reno, NV
    ~Don
    1. Is there a way to feed an offset in manually in Gcode
      By seanreit in forum General Metal Working Machines
      Last Post: 12-13-2008, 10:30 PM
    2. Solidworks to EMC2 Compatible GCode?
      By leeleatherwood in forum LinuxCNC (formerly EMC2)
      Last Post: 10-18-2007, 04:43 PM
    3. EMC2 gcode O-words and parameters
      By acondit in forum NCPlot G-Code editor / backplotter
      Last Post: 07-13-2007, 10:47 AM
    4. syntax error
      By pyroracing85 in forum G-Code Programing
      Last Post: 01-27-2005, 08:09 PM
    5. Syntax question
      By doug6949 in forum Mastercam
      Last Post: 12-13-2004, 02:14 PM
