Results 1 to 8 of 8
Thread: 2 axis contraption
    May 2005
    canada
    2 axis contraption
    First, apologies for not providing a photo. I'll get one up soon.
    The machine is a boom design. One axis is a horizontal screw driven linear axis. This axis pivots at one end to rotate in the horizontal plane. The second axis the rotary. The machine must make multiple rotations, 0 to some large number of rotations/degrees. It needs a working coordinate system.
    Is there an existing configuration to use as a starting point ? I'd prefer to not reinvent an existing wheel.
    Anyone who says "It only goes together one way" has no imagination.
    Dec 2003
    Am I right in assuming this does not need interpolated moves?
    How much operator input is required?
    You could do it with a Galil 1500 stand alone unit, the communication is by RS232, either using simple Galil commands with a PC or by a pre-programmed 2/4 line keypad/display by Maple systems to act as a simple HMI unit.
    I don't believe you will find an off-the-shelf system to do exactly what you want.
    May 2005
    canada
    Quote Originally Posted by Al_The_Man View Post
    Well, I'm hoping for interpolated moves. Sorry, I should have made it clear in the first post that this is a toy and an experiment. Here's a photo with a 6" caliper to give a sense of scale. Obviously some finishing touches are needed.
    My thinking is emc is used for robots, hexapods, pick-n-place and other stranger things so there might be a configuration that would come close. Or maybe I've found a new puzzle to work on. One thing for certain, it will be able to draw spirals
    May 2005
    canada
    You were right Al. not that I doubted you. Attempts at interpolation were weird at best.
    This thing draws good spirals and is also a pretty good wire twister. I have an idea on how to program this thing but need to check on the math first. Any further updates, if and when they happen, will be in this thread.
    first attempt sandtable
    May 2005
    canada
    Arghh ! Wrong photo.
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    Looks - kinda familiar
    Quote Originally Posted by cyclestart View Post
    From a "mechanical design" point of view - looks like you're (re)creatting a record (player) recorder!
    'Supose you've condsidered rotating the platten and just traversing the arm over the top? You could index the platten with a laser/spot marking system for a start on the polar coordinates.
    Don't know if thats any help - looks like a fun "contraption!
    Cheers - Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    May 2005
    canada
    Quote Originally Posted by High Seas View Post
    Watching the wire twist into a knot makes driving the platten appealing. A large ring and a rubber wheel would work given the "cutting forces" involved. Unfortunately I don't have a large ring in the spare parts pile. Also the arm needs to able to work underneath the surface. That's not a show-stopper but is an extra consideration.
    The current design needs a slip ring style connector unless someone offers a simpler solution to the wire twisting.
    edit/ Hah. Turntables were either direct or belt driven. Thanks Jim, the cogs are turning now !
    Sep 2003
    Glad the "nudge"was helpful!
    Cheers - Jim
    PS - Pics of the "final"would be a nice follow-up -- TIA
    1. Compare Catia and MCX2 for multi axis lathe/4 axis mill
      By bob1112 in forum General CAM Discussion
      Last Post: 10-10-2008, 08:15 PM
    2. How can I coupling a stepper motor axis directly to other axis?
      By meknik2001 in forum Stepper Motors and Drives
      Last Post: 05-08-2008, 02:54 PM
    3. One axis (z-axis?) computer controlled testing device
      By TsThorsell in forum Stepper Motors and Drives
      Last Post: 02-07-2008, 01:38 PM
    4. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
      By the__extreme in forum CNC Wood Router Project Log
      Last Post: 02-26-2007, 03:58 PM
    5. Please welcome... "Contraption 1"
      By JRoque in forum CNC Wood Router Project Log
      Last Post: 05-19-2005, 01:53 PM
