Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 05-18-2009, 08:51 AM
EvilBarry is on a distinguished road
EMC with QCad
Hi all,
I've nearly finished my MDF cnc and am waiting on the motors/electronics now. While im waiting i've been looking at using EMC and qcad with dxf2gcode in between.
I now have a query about this setup. Is qcad capable of producing a dxf with depth information within it so i can cut a resess without penetrating through wood being cut, and still have full through holes cut as well?
Many thanks
Barry
Old 05-18-2009, 09:50 AM
acondit's Avatar
acondit is on a distinguished road
My recollection is that QCad is 2d. However, some dxf to gcode programs will allow you to create different depth cuts for different layers.
Alan
http://www.alansmachineworks.com
Old 05-21-2009, 09:19 PM
BMG BMG is offline
BMG is on a distinguished road
There is also HeeksCAD which can import the DXF and with HeeksCNC you can generate the gcode. All doable in linux (windows version as well). I am pretty sure you can do 2.5 with HeeksCAD
HeeksCAD and HeeksCNC are both in the google code pages.
BMG
Old 05-23-2009, 06:53 PM
DMF_TomB is on a distinguished road
CAD CAM for EMC and free
also can try http://www.gsimple.eu/index.html
it takes a little getting use to and works better on metric stuff but I have used it before. Also can do engraving of text. Gsimple is not the best with 3D parts. I believe it only works with dxf files.
HeeksCAD and HeeksCNC sounds interesting and I will definitely check them out.
QCAD ronateah LinuxCNC (formerly EMC2) 11 03-03-2009 08:16 AM
Qcad ADucci Suggestions for the CNCzone.com site. 0 08-29-2007 03:35 PM
