05-07-2009, 11:06 PM
Originally Posted by RP Designs Well I guess my question is more like setting up servo's with a clean sheet of paper approach. If I where to set up a 4 axis mill and wanted to set up three axis with servos and encoder feedback and a 4th axis with steppers, how would I go about doing that in the software. The documentation for he stepper set-up seems pretty straight forward, but the servo set-up doesn't seem to be documented at all! i would like to see a servo set-up written step by step if possible just to get a feel of what needs to be done. Maybe it exists but I certainly haven't stumbled across it yet. i also want to see what sets EMC apart from Mach software, especially in the reals mof servos and closed loop controls. |
OK, first you need to decide on a servo interface device. There are now a dizzying variety of products available. You CAN, in theory, rig up servos with software encoder counting, and either software PWM or step-direction drive. This requires extra parallel ports, and loses some of the advantages of servos, such as high encoder resolution WITH high velocities. At some point, the software can't keep up with the step or encoder count rates.
Once you have chosen a servo interface unit, you can select a sample configuration file from the menu and customize from there. A number of sample files, including for my boards (Pico Systems) are included with EMC2.
Jon |
