Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 04-29-2009, 11:57 AM
shotgunn is on a distinguished road
please help find/choose linux CAM software...
Hey guys,
I will be running Ubuntu and using EMC2 for machine control. I plan on using either QCAD or TurboCAD on my Mac (OS 10.5) so I am not stuck in my shop for the CAD portion of my projects. I would like to use my linux machine for the CAM part of the process as well as machine control.
I have done some pretty extensive searching and would like to what people use here at cnczone. I have found a couple pieces of Linux CAM software, MonoCAM, and SheetCAM.
Does anyone have experience with these, or have any other Linux based CAM recommendations?
I would like my work flow to be as such:
1. Work out CAD drawings. On my Apple laptop, I can bring this anywhere. (i.e. the bathroom.)
2. Go into my shop, Import CAD drawing into CAM software on Linux machine.
3. Export G-Code to EMC2 for machine control.
Any tips or advice will be GREATLY appreciated. I'm new to this, but I have much computer background as well as manual machining.
Thanx in advance,
shotgunn
CM X1 (Harbor Freight), Probotix 3-axis kit, cncfusion X1 kit, Shuttle KPC 45, Linux Ubuntu, EMC2, QCad on Mac OS X 10.5
Old 04-29-2009, 05:36 PM
Seb Seb is offline
Seb is on a distinguished road
I have no experience with any Linux CAM software, but the Cam page on the EMC2 Wiki has a big list.
Old 04-29-2009, 05:40 PM
Bubba's Avatar
Bubba is on a distinguished road
I am new to linux, but have sheetcam on there and do some experimentation and confirmation from my windows based stuff. So far, I find it to be excellent on both the platforms.
Art
Old 04-29-2009, 10:00 PM
BMG BMG is offline
BMG is on a distinguished road
if you are generating cad files, save them to DXF and use DXF2Gcode. Do some googling and you should find a bunch of file converters. I have heard of several people using QCAD and a DXF to Gcode program to generate the buk of thier code. They usually run the resulting code in simulation to insure its what they want.
As to CAM programs, there is now a CAM IRC Channel you can log in to and get more concise answers to whats working well in linux (and whats not).
IRC Channel is #CAM on Freenode.org
HTH's
BMG
Old 06-05-2009, 08:15 PM
DesertRat50 is on a distinguished road
Ubuntu with EMC2
Shotgunn,
Like you I'm working toward a CNC router with Ubuntu with EMC2 for the CAM portion. However, I'm still trying to decide which CAD program to start with.
I haven't spent much time working with CAD programs so easy to learn would be best, but I don't want to waste time learning something that won't export files cleanly to EMC2.
Any recommendations?
Desertrat50
Old 06-06-2009, 05:11 AM
provo2007 is on a distinguished road
3d cnc software
need help
question can anyone help with 3d software for cutting rudder blades and are there mid priced packages that some would recommend
Old 06-06-2009, 10:33 AM
cyclestart is on a distinguished road
It reads like you're misunderstanding the roles of the different software.
CAD creates drawing files.
CAM imports those files and creates tool paths. It posts these tool paths in a language you're chosen interpretor will understand. Emc's interpretor speaks a slightly different dialect than some other controls. CAM has various post processors to accommodate these differences. Not all CAM has an emc post.
Some software (like Mastercam) has both a design (CAD) and a CAM component.
Emc does the interpretation of the gcode (post) file CAM posts.
So the real question is which CAM software creates a good emc post. Sorry if I'm being a bit nit-picky.
What type of complexity of parts do you hope to make. I work mostly in 2+1/2 dimensions so can't be much help with the fancy stuff.
provo2007
Are your rudders 3d objects like a propeller ? I'm curious if they might be 2+1/2 dimensional objects.
Anyone who says "It only goes together one way" has no imagination.
Old 06-06-2009, 04:07 PM
acondit's Avatar
acondit is on a distinguished road
Shotgunn,
I have QCad and VectorWorks12 on my Mac. I also use VCarve and NCPlot2 (both running under Windows XP on Parallels) to generate gcode from DXF files, but most of my gcode I just write by hand. I just stick the gcode file on a thumb drive and take it out to the shop, copy the code from the thumb drive to the nc_files folder, then fire up EMC2, open the file and go.
Alan
http://www.alansmachineworks.com
Old 06-11-2009, 01:48 PM
I have ended up using Vectric Cut2D for my CAM needs. I chose this because of a recommendation from Len (@ Probotix.com, GREAT GUY!!!) Not to mention the cost factor, $99 from Len. I just email myself the file when I need it on my linux machine. Doing that way is actually quicker than using a flash drive. Cut2D is PC based software. It works great, they have outstanding tech support, and it is very user friendly.
I hope that helps.
shotgunn
Tags
cam software, linux cam, linux cam software
what software to choose luiznunes General CAM Discussion 1 04-09-2009 05:59 PM
Linux software for dro R.thayer LinuxCNC (formerly EMC2) 4 12-03-2006 02:49 AM
Software for Linux Ringo42 LinuxCNC (formerly EMC2) 34 08-16-2005 02:28 PM
RS-232-C Software for RH Linux 9.0 smabhyan LinuxCNC (formerly EMC2) 6 07-11-2005 08:06 AM
CAD Software , Which to choose!! Hasher General CAM Discussion 6 04-02-2005 08:22 AM
