Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 04-11-2009, 10:23 PM
Monroe Design is on a distinguished road
Mesa 7i33 and AMC amplifiers
I am working on finishing my retrofit and have come across an issue. The mesa 7i33 outputs the +-10v analog signal on one pin and the AMC drive has analog + input on 1 pin and analog - on another pin. How would I connect it to work correctly?
Old 04-12-2009, 09:53 AM
Seb Seb is offline
Seb is on a distinguished road
You should check the manuals to make sure (read: i take no responsibility for if the smoke comes out!), but...
I would guess the drive wants the 7i33's ground on its "Analog -" input pin, and the 7i33's +/-10V output on its "Analog +" input pin.
Just a guess...
Old 04-12-2009, 10:09 AM
Al_The_Man's Avatar
Just a guess...
This way should work OK.
If you go to the AMC Engineering & Installation site, it shows typical schematics of interfacing to various equipment.
The 7i33's common will be the AMC -ref.
Servo Amplifiers at 240V CalG General Electronics Discussion 0 03-26-2009 09:35 PM
Anyone with Mesa 5I20 and 7I33 stories? karl1 LinuxCNC (formerly EMC2) 15 12-13-2008 11:28 PM
Problem using EMC with MESA 5I20 + 7I33 + 7137 hooeey LinuxCNC (formerly EMC2) 6 03-05-2008 03:39 PM
Trying to identify some servo amplifiers wpy Bridgeport and Hardinge Mills 19 11-08-2007 05:48 PM
glentek amplifiers yeepman2 Fadal 1 12-01-2005 05:44 PM
