Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 04-08-2009, 02:07 AM
linuxstep1 is on a distinguished road
Hot wire foam cutting with EMC
hi,
I'm new here and I joined this forum, because I plan to build a hot wire foam cutter. Main purpose of the cutter is to create parts for model aircrafts (wings etc).
The cutter will have four axis for wire moving (as usual), but with a less usual bipod kinematic. Additionally a turntable is planned.
My plan is to configure EMC with linear axes XYUV plus a rotary axis A for the turntable. This is probably the standard layout for this kind of machine.
I have already installed EMC2 on top of an existing Xubuntu hardy on a laptop. It went smoothly within less 1/2 h.
I know laptops are not recommended, and have already seen the latency is more than 1 msec ! For 1st tests it may be ok, but for real work I have to choose probably another hardware.
Now the first task is to create suitable ini and hal files. I will report progress from time to time.
Any suggestions, feedback, examples are welcome.
greetings
Gerd
Old 04-20-2009, 12:43 PM
Nick1983 is on a distinguished road
I am new when it comes to hot wire cutting. I am assuming you are cutting eps, is that correct?
Have you ever tried Crosslinked PE? I am going to try and v profile a thin piece of xlpe (approx 3/8" thick) down .33". I am setting up a manual fixture, no NC. Any advise?
Old 05-11-2009, 05:49 PM
nikodell is on a distinguished road
I would be interested to hear how you set up the bipod kinematic's could post what you did + code.
Old 05-26-2009, 06:49 AM
hotwire cutter is up and running
a short report about the result:
enjoy some pictures about the machine and a cutting sample.
Attached also the kinematics and ini, hal
Gerd
ID:	81940   Click image for larger version
ID:	81941   Click image for larger version
ID:	81942   Click image for larger version
Old 05-30-2009, 11:18 AM
vlmarshall's Avatar
vlmarshall is on a distinguished road
Nice work, thanks for sharing it!
Old 09-04-2009, 08:00 AM
Nice Work I will have a look now as I have some time again.
Thanks for posting the work>
Old 09-10-2009, 10:25 PM
dpuch is on a distinguished road
Very nice, and thank you for sharing the files.
A bunch of questions about how well it is working for you.
Have you had any issues with it? Like the bow swinging or the lines not wrapping right. What about repeatability from cut to cut, do the lines stretch causing problems?
Are there any problems with the wire position if you transition to an angled cut? Say X+3" and U-3" will the wire change height any? Granted I think that would depend on how your lines connect to the bow wire.
Dale
Old 09-11-2009, 07:34 AM
Repeatability and accuracy is good enough for the given purpose (model aircraft parts).
Swinging of the bow is not a real problem, because the bow may swing but the wire moves straight.
The Material for the lines is Dyneema (used for fishing and kites). It is said that it does not stretch, and I believe it.
Angled cuts are generally ok. There are small geometric unaccuracies, because the point where the lines are connected to the wire are fixed. I thought about an additional "fixture" to keep the lines always "upright". But I think its not worth.
Biggest problem is the cutting speed. I became aware of the following:
A G1 command with X-Y-U-V axis is executed in EMC2 with the given speed always related to X-Y. The U-V axis move with a speed depending on the distance of UV relative to XY. This is a problem when the XY distance is very short compared to the UV distance. Then the UV side tries to move very fast.
regards, Gerd
Old 09-11-2009, 12:29 PM
regards, Gerd
I guess the ideal setting would be the feed is a max feed regardless. Good to know to put the large ends to the XY side though.
The simplicity of the build has motivated me to make one myself. I have wanted to put one together for a while for the same thing, airplane models.
Old 09-11-2009, 12:53 PM
Yes, but there are some more special considerations, depending on how the G-code is created. I use an italian software called profili.
Yes go ahead, its really simple to build. Would be nice to see some photos.
And this is the original site: cnc-hotwire (in german)
regards, Gerd
  #11   Ban this user!
Old 09-11-2009, 02:02 PM
English translate
http://translate.google.com/translat...-hotwire.de%2F
  #12   Ban this user!
Old 09-11-2009, 02:05 PM
And I thought yours was simple
Need A Quote- Wire for foam Cutting "EdgeSweets" machine singerdon49 Employment Opportunity 0 12-29-2008 08:12 AM
Best wire for foam cutter ? fomaz CNC Wire Foam Cutter Machines 6 12-22-2006 02:17 PM
EPS foam dust or hot-wire fumes? Charlye Safety Zone 2 03-16-2006 04:19 PM
CNC Hot wire Foam Cutter Krashlnd CNC Wire Foam Cutter Machines 7 01-16-2006 07:57 PM
Bobcad wire EDM for foam onthemarc BobCad-Cam 6 07-18-2005 09:13 PM
