Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 04-02-2009, 10:28 AM
benjon is on a distinguished road
how to make embroidery from g code???
need help,
I want to make embroidery from g code.Problem is i know ~nothing about g codes.The idea is to transform embroidery format{down attached}into g code .I have my sewing machine attached to a x-y table and z is sewing head with 3 servo motors.Hardware is easy ,software is unknown for me.
My wish is somebody help me to transform embroidery format to g code ,and in place of punching to use drill,tap or something.xy coordinates i can copy paste from embroidery file ,i can delete in Excel columns i dont need ,i let there only x and y,and now ...what is hard for me...must put a kind of z coordinate or g drill code(maybe in each line) to make stitch in that place[x,y coordinate.]
who can tell me a formulas to transform each x-y line position into drill (punch)
and if i want to use more colors i just use more tools[and then i change thread]
Old 04-02-2009, 08:43 PM
BMG BMG is offline
BMG is on a distinguished road
To start, you might want to visit this "thread" - No pun intended.
http://cnczone.com/forums/showthread.php?t=57404
Second, there are at least two ways you could consider the stitching . I am sure more variations could be brought to bear, but the two most obvious are continuous and endpoint
By continuous, I mean stitches just like you would see along a seam. Stitch spacing is controlled by the machine settings and if its less than the length of the vector in question, then you basically build it with small vectors(stitches) in a line. This should simply require you to have an on/off switch for the "spindle" aka needle in this case. The spindle would run at some constant velocity and you control stitch lengths by a setting on the sewing machine. At the endpoints of a given vector, the spindle is toggled off (in an up position)
BY Endpoint mode, the needle makes one pass into the fabric at the start of the vector, it is then lifted and moved to the endpoint of the vector and a second pass into the fabric is made. This allows the making of variable stitch lengths. The needle position would be a "z" axis. If you want multiple stitches in a given vector, then simply breaking the original vector into smaller pieces of the desired stitch length would answer
Based on your machine description, it sounds like you could use gcode with an "endpoint"mode in mind. This is also possibly the easiest to gcode.
Now looking at your file, in a spreadsheet - plotting and XY graph with the XX and YY columns makes a nice maple leaf with the exception of the 1st two lines of code. They start at 0,0 and go clear across the fabric.
The first 2 lines would be a G0 move
All the remaining lines would be G1 moves with a Z to force the needle to stitch at each endpoint
For example
g0 x0 y0 zo
g0 x34.5 y36
g1 z-1 (what ever triggers a stitch)
g1z0
g1x32.5y29.5
g1z-1
g1z0
g1x.......
ad nauseum until the end of the file.
Thats a start anyway. I am sure plenty of others will chime in with different ways of tackling this.
It would help if you could describe your controls of the z axis better. that will certainly be a key point.
Old 04-03-2009, 02:06 PM
My machine is like i told before x -y table ,and electrical motor of machine replaced with servo motor ,that means few rotation of servo motor =one punch.
i understand first 2 lines must be G0 ,but i cant do something to maintain original x y lines [is easier to modify so in excel] something like ;
1.g0 x0 y0 zo
2.g0 x34.5 y36 z-1 (what ever triggers a stitch) z0
3.g1x32.5y29.5 z-1 z0
4.g1x......??
and if program cant hadle 2 z position in one line , i read somewhere that is a G code 83 or.84 i dont remember well, but this must do something like drill punch tap or something....??
i apologize but i really dont know about g codes too much just search a easy way to transform those x y position in g code for punch.. be patience with me..i give a beer
Old 04-06-2009, 01:30 PM
BMG BMG is offline
I see what you are trying to do.
Your right, Gcode is not going to like two Z commands in the same line (unless a drill cycle perhaps - not familiar with em). Simply inserting two z commands as separate lines is pretty simple.
I did it by creating 3 separate column pairs. The first pair was a sort number (1, 1+3n,...) plus a concatenate function creating a G1 code line for the XY pair from your sheet. The second pair was a sort number (2,2+3n,...) and a text line G1 Z-1.0 (needle down). The thrid pair was sort number (3,3+3n,...) and a text line G1 Z1.0 (needle up).
I then stacked each column of pairs and sorted. The sort number put a Z down and up after each XY move.
Save the result to a text file an away you go.
Hope that helps.
BMG
Old 04-06-2009, 08:20 PM
Zig Zig is offline
Zig is on a distinguished road
You are fortunate Your stitching file is in asci format human readable form.
As is you will need to break down each STITCH line of source text into multiple G CODE lines.
If You know how to write a bit of software to parse the stitching file then the next step is to read the file line by line and write down what each line of stitching file means in terms of machine action and then come up with G code equivalent commands to achieve desired motion.
Once You understand the realtionship between stitching file and G code you can write Your software to directly translate the stitching file intop G code.
So as a starting point analyse stitching file and see how many different kinds f stitching statements there are and what each statement means and we might be able to help with conversion to G code to get You on Your way.
Old 08-18-2011, 04:31 AM
flavio is on a distinguished road
INALAC_ROBOTICA FABRICANDO BORDADORAS COMPUTARIZADAS "HUBORDIX" Proyecto de construccion de bordadora computarizada-solicitud de informacion - LoboSolitario.com eclipseproyect: Parte 9: Eclipsepunch chek this links I hope help you in spanish I working in the same proyec
New Machine Build- DIY- CNC Embroidery Machine Khalid CNC Wood Router Project Log 466 08-20-2011 09:13 AM
Embroidery machines Karl_T CamSoft Products 12 04-08-2010 09:42 AM
Cant make this code run properly ganderboy G-Code Programing 11 10-30-2008 04:36 AM
Trying to make this work- G code WOODKNACK TurboCNC 17 06-10-2003 12:00 PM
