Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 03-23-2009, 12:44 PM
visky is on a distinguished road
Question Pluto-P board question ?
Hello!
I bought Pluto-P board and would like to start useing it but i dont understand this ...
The counters operate in "4x" mode. The
maximum useful quadrature rate is 8191 counts per emc2 servo cycle, or about 8MHz for
EMC2’s default 1ms servo rate. ...... ( from EMC2 integrator manual )
What does it mean ' servo cycle '?
How much is the maximum encoder pulses per revolution ?
Can i use encoder with 5000 pulses ? without loseing counts
Regards
Old 03-23-2009, 04:33 PM
acondit's Avatar
acondit is on a distinguished road
A quadrature encoder is capable of producing 4 times the number of counts that it has marks for. So, a 1000 count encoder would produce 4000 pulses per rotation in 4x mode. What happens is that there are at least two detectors in the encoder and as a result for each mark channel A produces a high going pulse and a low going pulse and the same for channel B. So four pulses for each mark.
I believe that it is saying that 8192 counts per servo thread period (1 millisecond) and approximately 1000 periods per second giving you around 8 million pulses per second.
RPM / 60 = rotations per second. Counts per rotation X rotations per second = counts per second. So it depends on how fast you want to spin the motor.
5000 pulses per rotation (your talking about a 1250 count encoder right?). 8,000,000 / 5000 = 1600 rotations per second. 1600 * 60 = 96000rpm. I don't know whether my math is correct or not but if so that is a seriously fast read rate.
Alan
http://www.alansmachineworks.com
Last edited by acondit; 03-23-2009 at 04:48 PM. Reason: A little more explanation.
Need Help!- Pro board question Kristin D Hobbycnc (Products) 0 04-04-2008 05:32 PM
question about hobbycnc non-pro board maxboostbusa Hobbycnc (Products) 5 10-21-2007 10:29 PM
Pluto-P Friendly BOB epineh LinuxCNC (formerly EMC2) 5 08-05-2007 06:56 PM
Question on a board RTI Guy Fadal 5 07-26-2007 02:11 PM
Bridgeport board question. Please help fredhh47 Machine Problems, Solutions , Wireless DNC, serial port 7 08-17-2006 03:07 PM
