Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 03-18-2009, 09:39 AM
zeeshan.insight is on a distinguished road
Axis shift during machining
I am using emc2 to control motenc lite controller. And using mastercam for creating nc data. the problem is that while machining x-axis shift to +ve side and z-axis take more depth than define. i explain it with an example " i make a rectangle of any size and make a program of conour on outside boundary. Define z total depth -1mm and depth of cut .01mm. During the machine running x shifts to +ve side and z ends with the depth more than -1mm. Anyone can help me out.
Old 03-18-2009, 09:57 AM
Big John T is on a distinguished road
Is this a stepper system?
Are you loosing steps?
http://www.linuxcnc.org/docview/deve...tics.html#r1_3
John
Old 03-19-2009, 04:34 AM
No these are contraves servo motors with 2500 ppr encoders.
Old 03-19-2009, 09:04 AM
i am attaching images of a job in which x-axis shifting to one side. It might give the clear picture
Old 03-19-2009, 09:16 AM
That's a pretty clear picture. I would have to guess some kind of hardware problem. Perhaps someone else has a better idea.
John
Old 03-19-2009, 09:29 AM
John by the hardware i think you mean about ball srew, motor mounting, pulleys etc.
Old 03-19-2009, 11:31 AM
PCW_MESA is on a distinguished road
Might also be x axis encoder losing or gaining counts (electrical noise?)
Old 03-19-2009, 02:26 PM
and like Peter said electrical too...
John
Problem- c axis work shift Atlas_Too Fanuc 3 10-13-2008 12:14 PM
5 axis machining. samco LinuxCNC (formerly EMC2) 9 07-03-2008 02:07 PM
Setting Z axis with G92 work shift venomgrrrl Fanuc 12 12-03-2007 11:02 AM
5-Axis Machining 5AxisMachining General Metal Working Machines 3 03-21-2005 09:03 AM
4th axis machining senor J. Visual Mill 0 10-22-2004 03:10 PM
