| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I have an EMC2/Ubuntu 8.04 installation on a Dell Dimension L667r. Once emc2 starts the axis interface, the display (in and out of the emc2 window) has horizontal bands. You can see most of the display, but it is not that useful. The tkemc and mini guis display fine. 1. Is axis that much better that I should figure out how to make it work? 2. What can I try? The problem reappears when I change the screen resolution via system->preferences->screen resolution. What else can I do? Thanks |
Hardy 8.04 has been a bit of a step backwards for some hardware Sometimes it doesn't become obvious until you try an openGL app.What's your graphics hardware ? (model, card or onboard, monitor) A proprietary driver (you would have been asked for permission before installing) or the default open source driver ? Code: lspci Code: cat /var/log/Xorg.0.log | grep Driver Code: cat /var/log/Xorg.0.log | grep -i render\* I'm grasping at straws here a little, but more info never hurts. Maybe someone here is running similar gear. There's a a driver called vesa if all else fails but it can be ugly or not work at all..
__________________ Anyone who says "It only goes together one way" has no imagination. |
samco, I installed from the livecd. I forgot to mention that the first thing I checked was that the visual effects were disabled. I thought that would have done it, but no such luck. cyclestart Here are the specs of the system. $ lspci 00:00.0 Host bridge: Intel Corporation 82810E DC-133 (GMCH) Graphics Memory Controller Hub (rev 03) 00:01.0 VGA compatible controller: Intel Corporation 82810E DC-133 (CGC) Chipset Graphics Controller (rev 03) 00:1e.0 PCI bridge: Intel Corporation 82801AA PCI Bridge (rev 02) 00:1f.0 ISA bridge: Intel Corporation 82801AA ISA Bridge (LPC) (rev 02) 00:1f.1 IDE interface: Intel Corporation 82801AA IDE Controller (rev 02) 00:1f.2 USB Controller: Intel Corporation 82801AA USB Controller (rev 02) 00:1f.3 SMBus: Intel Corporation 82801AA SMBus Controller (rev 02) 01:09.0 Multimedia audio controller: Ensoniq ES1371 [AudioPCI-97] (rev 06) 01:0a.0 Ethernet controller: 3Com Corporation 3c905C-TX/TX-M [Tornado] (rev 78) $ grep Driver /var/log/Xorg.0.log X.Org Video Driver: 2.0 ABI class: X.Org Video Driver, version 2.0 Module class: X.Org Video Driver ABI class: X.Org Video Driver, version 2.0 Module class: X.Org XInput Driver Module class: X.Org XInput Driver (II) intel: Driver for Intel Integrated Graphics Chipsets: i810, ABI class: X.Org Video Driver, version 2.0 ABI class: X.Org Video Driver, version 2.0 ABI class: X.Org Video Driver, version 2.0 ABI class: X.Org Video Driver, version 2.0 $ grep -i render /var/log/Xorg.0.log X.Org Font Renderer : 0.5 Module class: X.Org Font Renderer ABI class: X.Org Font Renderer, version 0.5 (II) intel(0): Direct rendering enabled (II) Initializing built-in extension RENDER I have the package xserver-xorg-video-vesa installed. What is the best way to try it out? Do I edit xorg.conf, or is there a more polite way to try it out? Thanks again. |
| Go here http://www.linuxcnc.org/content/view/4/8/lang,en/ and do a search of the user-mail-archives for the term "i810" I didn't have time to give it a full read. Got to run. Good luck.
| Thanks for the tip. In /etc/X11/xorg.conf I added a line to the "Device" section so it looks like this. then restarted x with ctrl-alt-bksp By the way, adding this line or this line did not work at all. Had to ctrl-alt-f1 and login to revert xorg.conf to a working version. |
| http://thread.gmane.org/gmane.linux....emc.user/10390 The similarity in names is more than a coincidence I think ![]() 8.04 is mis-configuring some older graphics hardware that worked in 6.06. There are other examples.
Jon |
| HS1 horizontal mill with auxillary axis alarm | teal854t | Haas Mills | 2 | 04-18-2009 12:47 PM |
| origin axis display in x3 | 1ctoolfool | Mastercam | 2 | 01-11-2009 05:20 PM |
| HORIZONTAL MILLS | fastlanecafe | General Metal Working Machines | 3 | 08-16-2008 06:56 PM |
| B axis for horizontal mill OM | nabil_elbadri | Fanuc | 3 | 11-16-2007 06:19 PM |
| 4-5 axis control recomendations for home built horizontal machine | Kmed | General CNC (Mill and Lathe) Control Software (NC) | 3 | 01-17-2005 04:04 PM |
