| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hi! I have a problem that someone in here might know how to solve. I have a laser mounted in a 3-axis router and would like to be able to switch it on and off from G-code without having to stop the movement. For example: __________ G1 X30 G3 S100 G1 X50 __________ This will make the X-movement come to a stop before the laser is turned on and then accelerate up to the specified speed. Can I make this operation with constant X-speed? Do I have to use the ClassicLadder for such an operation? Alternatively: Is there a function in EMC2 that is able to compensate, in the M3 S-value (normally spindle-speed), for the velocity of the machine-head? I'm told there is a function like this in Mach3 and I guess it would do the trick for my laser problem. Thnx! /Tottish |
| In 2.3 beta you can use M62/63 to do that. http://www.linuxcnc.org/docview/deve...ec:M62-to-M65: John |
| I don't think so: "The actual change of the specified outputs will happen at the beginning of the next motion command. If there is no subsequent motion command, the queued output changes won't happen. It's best to always program a motion g-code (G0, G1, etc) right after the M62/63." From what I can tell this means that the router has to come to a stop and then start moving again for an M62/63-command to "execute". I need it to turn the laser on while moving. Preferably I would like to be able to set the M3 PWM that I now use for the laser but if only on/off is possible I guess it will do. Any other Ideas? Regards /Tottish |
| hmm, got a double post... anyway the above move will be one smooth move within the constraints of your system. http://www.linuxcnc.org/docview/deve...epts.html#r1_1 So it might be needed to have a G1 move before and after to maintain speed as outlined above. John |
| Sorry Big John. I'm new to G-code manipulation and I didn't realize that the M62/63-commands would fit in seamless. I tried doing the same thing with the M3-command and since that didn't work I thought that the code was executed line by line without any knowledge about what's on the next line. It seems I came to the wrong conclusion. Is there any way to fit in the M3 command like that? It would just be awesome. If not I will probably have to sweep the whole image one time for every shade that I want. Thanks a lot Big John and sorry for mistrusting you. =) Regards /Tottish |
| Hmm, I was wrong (again). It only works for me at slow speeds. At speeds over 500mm/min it becomes clear that it does stop (or at least slow down) between the lines. Even without the M-commands it stops. For example this block: G1 X10 X 20 X30 Is performed in three distinct sequences at higher speeds. I have to double check for errors tomorrow. My head is spinning around right now. Good Night from Norway! /Tottish |
#10
| Did you set G64 Pnn ? http://www.linuxcnc.org/docview/deve...ts.html#r1_1_3 For short moves at high speed this is needed. Also EMC will not go faster than it can stop so if your acceleration is low and your asking for high speeds it looks like a bumper car... John |
#11
| I have now. But I'm afraidit didn't help. When I run this program> T1M6 G64 P0.5 G1 Z0.5 F2100.0 G0X0.000Y0.000 G1X8.525F2100.0 x10 X11 X12 X33 X34 X35 X50 G0X0.000Y0.000 G0X0Y0 M30 Everything runs smooth and it seems as if the naive CAMthingy 'morphs' all the Xmoves together and in the CodeWindow of AXIS the highlight skips right down to the last Xline and stays there until the value X50 is reached. When I run this program, however, it is all chopped up and not smooth at all> T1M6 G64 P0.5 G1 Z0.5 F2100.0 G0X0.000Y0.000 G1X8.525F2100.0 x10 M62 X11 M63 X12 M62 X33 M63 X34 M62 X35 M63 X50 G0X0.000Y0.000 G0X0Y0 M30 The highlight is jumping from row to row. Any more pointers of what might be wrong here (questionmark) Regards, Tottish EDIT: Oh, and the P-value for the G64 makes no apparent difference. |
| Need Help!- New SX3 - Axis Movement | meyermicro | Syil Products | 11 | 05-27-2008 08:36 AM |
| Axis Movement | KARD | CamSoft Products | 1 | 05-21-2008 05:29 AM |
| No Z-Axis Movement | btcoutermash | Bridgeport and Hardinge Mills | 11 | 08-12-2007 02:42 PM |
| Axis Movement | UKRobotics | General Metal Working Machines | 2 | 12-17-2004 01:33 PM |
| 4th axis movement (and a few other gen ?s) | corpse | General Metal Working Machines | 2 | 08-04-2004 06:13 PM |
