Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 02-27-2009, 12:37 AM
tottish is on a distinguished road
PWM outputfrom EMC2
Hi y'all!
I've used EMC2 for my simple 3-axis CNC-router for about a year now so I'm familiar with the AXIS user interface and the StepConf-wizard but other than that I know very little about EMC2.
I'm about to hook up a laser to the machine and here is where I need your help.
1. To start out with I would just like to be able to turn the laser on and off from EMC2 (a TTL-level logic signal or similar would do fine) and I guess that should be simple enough, still I don't have any experience in this area and would much appreciate your opinion on the simplest way to implement this.
2. Eventually I would also like to be able to control the output-effect of the laser which is determined with a 24kHz PWM. Is this possible to get right out of the parallel-port of the PC?
Thanks a lot, hope you can point me in the right direction.
Regards
/Tottish
Old 02-27-2009, 11:26 PM
chester88 is on a distinguished road
To turn an output on and off you might use M62 -65.
In stepconf select 'digital out' on one of the parallel port pins
then M62-65 can control it.
read more in the manual.
Old 02-28-2009, 02:34 AM
Thanks a lot Chester! I will check those out in the manual.
Any idea about the PWM thing? I was thinking I might use some output meant for a RPM regulator or something like that. Maybe they are all controlled by analog voltage?
Regards
/Tottish
Old 02-28-2009, 12:59 PM
have you looked at the emc wiki?
In the wiki search laser
for instance here:
http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?M5i20_Laser
This was done using some custom hardware but the principal is the same.
Unfortunately I don't think there are M commands to set analog outputs.
This would be a good feature request.
It could be done using custom g code subroutines to set the pwm generators pulse rate.
look under G100-199
Need Help!- EMC2 Jamy LinuxCNC (formerly EMC2) 32 08-17-2009 11:03 PM
Newbie- 3D DXF EMC2 or 2D only? klaymonster LinuxCNC (formerly EMC2) 7 01-14-2009 04:22 PM
EMC2 HELP HELP HELP Alwyn OpenSource Software 2 10-11-2008 11:18 AM
Need Help!- M8 still not being red by EMC2 SpeedsCustom LinuxCNC (formerly EMC2) 27 04-13-2008 03:36 PM
Emc2 sdantonio Mach Mill 2 02-05-2007 02:26 PM
