Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 02-21-2009, 12:44 PM
alidigital is on a distinguished road
EMC + Sherline 5400 + K179 controllers + step syn & astrosyn motors
Aloha ya'll - working to get this assemblage running
As stated we've got a
Sherline 5400
3 k179 stepper controllers
z-axis ='s step syn motor (p/n 2462561) rated at 2 degrees per step 1.4 Amps, 4.5 Volts
x,y axis ='s astrosyn miniangle stepper (type 231 mc705) 1.8 degrees per step 2.4 Amps, 3 Volts
and we'd like to see this machine work with EMC. As a total novice in this realm we need some help getting the .ini and .HAL files prepared (I think that's what is needed - again, total novice here)
Ran the configuration wizard & see a list of variables - listed here as at the end of the day hope to fill in the blanks for any future novices - could someone please lend a hand? Thank you in advancee
From K179 controllers
Step time ns
Step Space ns
Direction Hold ns
Direction Setup
Parport Base Address
Latency test result
Motor steps per revolution
Drive microstepping
Pulley Teeth (motor:leadscrew)
Leadscrew Pitch mm/rev
Maximum Velocity mm/s
Maximum Acceleration mm/s2
Home Location
Table travel (a to b)
Home Switch Location
Home Search velocity
Home latch direction
Spindle Configuration
PWM Rate
Calibration
Speed 1:
Speed 2:
Tags
astrosyn, emc, k179, sherline, step syn
Sherline 5400/5410 A2Zcnc upgrade genexis Benchtop Machines 3 07-06-2010 08:03 AM
First G10 CNC Cutting with sherline 5400 genexis Benchtop Machines 0 06-27-2007 10:42 PM
Sherline 5400 Motor Hot greasetattoo Benchtop Machines 2 03-10-2007 11:10 PM
Sherline 5400, X2, or Taig? tipschips Taig Mills & Lathes 20 08-01-2006 08:25 PM
sherline 5400 Preload nut dneisler Benchtop Machines 1 11-28-2005 11:40 AM
