Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 02-16-2009, 08:14 PM
TZak is on a distinguished road
Changing M5i20 Output signals
Ok getting closer to getting this machine working however.
Here is my situation.
I have EstopWrite hooked up to a relay to my amps. So if there is a failure to the system power is stopped to the amps. At least that what the comments are on the mesa_io.hal file tell me. However I am getting no output signal on m5i20.0.out-07. Please if someone has an idea of how I can hook this up correctly it would be appreciated. Or should I connect this to a different output.
Here is the current area of the code that I am trying to modify.
# Connect e-stop write/sense to I/O controller.
# The estop from the opto module should be jumpered to one of the
# m5i20 estop pins. This will notify the motion of the estop condition
# and it will zero the DACs and turn off all output even if the PC
# has crashed.
newsig EstopSense bit
newsig EstopWrite bit
# create a signal for the estop loopback -- remove for external
#linkpp iocontrol.0.user-enable-out iocontrol.0.emc-enable-in
# use this if you have an external estop switch
#linksp EstopSense <= m5i20.0.estop-in-not
linksp EstopSense <= m5i20.0.in-15-not
linksp EstopSense => iocontrol.0.emc-enable-in
linksp EstopWrite => m5i20.0.out-07
linksp EstopWrite <= iocontrol.0.user-enable-out
Also does anyone know how to invert a output signal on the mesa. I also need to change the spindle output from 3.5v at startup which it is now, to 0v. And then when I run the program my relay can turn on the spindle.
Here is that code from the mesa_io.hal
# Connect spindle fwd/rev to I/O controller.
newsig SpindleFwd bit
linksp SpindleFwd => m5i20.0.out-00
linksp SpindleFwd <= motion.spindle-forward
The current system is running emc2 2.2.8 on Ubuntu 8.04
I hope this makes sense and someone can help.
Old 02-17-2009, 12:28 PM
DonnieET is on a distinguished road
Hi
I'm fairly new at this too. Are you getting any outputs? I haved a problem with the watchdog not get set the file I started with had watchdog commented out.
On inverting the output is something like this
Setp m5i20.0.out-00.invert 1
Mine is a little different in that I use the 5i23 with a 7i33 and 7i37 card and the hostmot2 driver were you have the orginal hostmot witch I should have used.
Donnie
Old 02-17-2009, 07:09 PM
123CNC is on a distinguished road
I said STOP!
Bringing back fond memories.
I am not using HOSTMOT2, rather the default (older) EMC 5i20 configuration. To invert an input just add '-not' to the signal.
Here are the modifications I made to make a functional e-stop.
# Connect amp enables to motion controller.
linksp Xenable => m5i20.0.out-03
linksp Yenable => m5i20.0.out-09
linksp Zenable => m5i20.0.out-04
# Connect amp enables to m5i20 dac enables
linksp Xenable => m5i20.0.dac-00-enable
linksp Yenable => m5i20.0.dac-01-enable
linksp Zenable => m5i20.0.dac-02-enable
linksp EstopWrite <= m5i20.0.in-15
linksp EstopSense => m5i20.0.out-07
I am not using the watchdog.
The amp enables get tied into the internal e-stop logic. I also tie the amp's ac power to the m5i20.0.out-07 signal, physically. The enables only should cover you, but I like to kill power all the way down to life support on an e-stop, i.e. controller only thing alive.
In my case, I don't believe the EstopWrite has any functionality.
This part just didn't make any sense to me,
Old 02-17-2009, 09:26 PM
Talking
With Hostmot2 you have no choice on the watchdog, pet it or die.
Old 02-17-2009, 09:31 PM
Seb Seb is offline
Seb is on a distinguished road
It's a bummer that first example hostmot2 config had the watchdog commented out in the .hal file... I think that confused lots of folks.
The new hostmot2 configs in 2.3 all have the watchdog working right.
Old 02-18-2009, 12:35 AM
New dog?
How about, 'my watchdog doesn't bite...that's not MY watchdog.'
The last post sounds like the 'watchdog' Donnie was referring to got hauled to the pound.
I have a 5i23? board waiting in the wings for a future install on another machine, but want to allow others the golden oppurtunity to blaze a new trail. So PLEASE keep us updated with your journeys.
Old 02-18-2009, 12:43 PM
Talking
123CNC
The thing about that watch dog, he was one of the silent type never heard or saw him just felt the bite
Donnie
Old 02-21-2009, 04:50 PM
Ok I have an update
I figured out how to do the invert output
setp m5i20.0.out-00-invert 0 or 1
thanks everyone for the help
so I have all my safety signals working correctly and also the spindle. The problem now is I am not get a PID on the X and Z channels. I have checked and I am just getting a High signal on the X and Z.
I know all my amps are working as I have switched the working y axis to the two other channels and it works.
The only thing I can think of is the mesa 5i20 board has a problem. Mind you I am getting all the other outputs and inputs working on it? If someone knows how I can test the card to see if it is in working order. I know all my settings work as I have had this system working to cutting parts.
Again help is always appreciated
Old 02-21-2009, 08:39 PM
chester88 is on a distinguished road
Here is a test panel:
http://wiki.linuxcnc.org/cgi-bin/emc...vcp_Test_Panel
Old 02-21-2009, 08:55 PM
How do you set up the test panel correctly?
  #11   Ban this user!
Old 02-21-2009, 09:22 PM
PCW_MESA is on a distinguished road
Originally Posted by TZak View Post
Ok I have an update
Our experience is that a failed (damaged by excessive I/O voltage) 5I20 card will almost always completely fail (will not even configure). Having just a few bad I/O bits is possible but really unlikely. If you can configure the card and the majority of I/O works, It is most likely your problem lies elsewhere.
If you can boot DOS or Windows (requires driver installation) on your test computer, we can supply a GPIO or loop-back test program. Or you can send the card back to us for evaluation and repair/replacement if needed.
Another way to check for open/damaged I/O pins is to use a Digital Volt Meter (DVM) that has a diode check function. Unplug the 5I20 card from the PC and remove all 50 pin cables, then with the DVM set to diode-check function, connect the positive DVM lead to 5I20 ground and check each of the I/O pins. They should all have similar voltage drops (~.5v), a bad pin will normally show open or shorted (higher or lower than a diode drop voltage) You are checking the I/O protection diodes in the FPGA
  #12   Ban this user!
Old 02-21-2009, 09:49 PM
if you could let me know how to get a test program that would be great.
I have downloaded the support software on the mesa electronicssite, however Im not exactly sure how to test the board,
I have a spare windows machine that I can check it on I just need to know how to configure the software to test it.
If you could let me know what I need that would be great.
thanks.
M5i20 & spindle control albova LinuxCNC (formerly EMC2) 2 05-12-2008 06:00 AM
Help Changing VQC inout/output Moparmatty Haas Visual Quick Code 5 03-12-2008 11:36 AM
Need Help!- Changing Arc Output? Moparmatty Mastercam 6 01-30-2008 08:34 AM
parallel port settings/output signals TMaster Xylotex 6 04-23-2006 11:16 PM
To convert Quadrature Encoder signals to Tachogenerator signals Babar General Electronics Discussion 4 02-21-2006 12:05 AM
