Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 02-13-2009, 05:04 PM
clutch is on a distinguished road
LPT ports needed for a mill
Howdy, this is my first post to cnczone, I've been lurking for a while.
I want to build a 3 axis mill initially with a 4th axis (A) for gear cutting and dial engraving down the road.
How many parallel ports would I need? Are there pci cards out there that are recommended with multiple ports?
Thanks,
Clutch
Old 02-13-2009, 08:03 PM
acondit's Avatar
acondit is on a distinguished road
You can run a 3-axis mill from a single parallel port, but take a look at the Mesa 5I20 pci card. It has lots of IO and encoder support also. You might also take a look at Mesa's 7I43. I believe that it will run off of a single epp parallel port.
Alan
http://www.alansmachineworks.com
Old 02-14-2009, 05:10 PM
The 5I20 looks like a nice board. I'm still trying to figure my way. Likely you noticed that from my question. From what I saw, if I decided to make some big iron full servo that dog can hunt.
I bought a breakout board from Keling Technology today and some steppers and other bits from electronic goldmine to make a stepper driver. Stepper doesn't have enough torque to do much useful other than let me see EMC2 working.
I have so much to learn.
Clutch
2 Parallel ports DrStein99 LinuxCNC (formerly EMC2) 12 08-12-2010 07:58 AM
Ports and Pin Setting BSims66173 Tormach PCNC 6 01-21-2009 08:56 PM
More on ports and pins andrewbishop66 Mach Software (ArtSoft software) 2 03-08-2007 07:05 PM
SPC Ports What are your Use? SMW Precision Calibration & Measurement 1 07-31-2006 03:46 PM
3.3 V vs. 5 V TTL on parallel ports HansM Machine Problems, Solutions , Wireless DNC, serial port 4 07-28-2005 02:28 PM
