| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
i'm running emc with a gecko540 and i'm only just ready to start but for my lack of information. the latency was my first prob but i soon fixed that. i then ready the entire HAL instructions because i couldn't find the on button anyway the problem i have now is my limit switches they seem to require a different setting each time i turn them on. one day x inversed, y z normal the next all inversed. i keep bouncing between emc and the configuration panel and then when i jog it hits the switch and repeats the limit switch error. one theory i have is that my config is set for two open switches in parallel and the gecko takes two closed switches in series. i don't know. but it is very erratic . |
| The general rule is that you don't want your limit switches wired NO (normally open) and parallel. The rational is that if a wire broke, you wouldn't notice until you ran into a limit switch and it didn't work. One can also come up with a scenario where a circuit with NC switches wired in series could also fail in an unnoticeable manner, but there are fewer points where the circuit could fail in an undetectable manner. Alan
__________________ http://www.alansmachineworks.com |
Because you are not supposed to hit the limit switches. If you hit a limit switch, you have created an error. That is why you have to tell emc2 if you are using limit switches as home switches as well. So that it can ignore the limit switch error and treat it as the home switch during a homing operation. Alan
#10
| This is also the case with one of my axes. Always error on the forst Homing after power on. After the first one everything seems to be working as expected. Have you goeetn this issue solved? regards Chris |
| Newbie- Limit switch Error | friklin | DIY-CNC Router Table Machines | 8 | 06-24-2008 05:14 PM |
| limit switch and home switch setup | Runner4404spd | General Electronics Discussion | 0 | 12-15-2005 07:58 AM |
| Is it possible to use the home switch as the limit switch as well? | Darc | Mach Software (ArtSoft software) | 2 | 10-23-2005 12:50 AM |
| Limit Switch / Home Switch in Software | Sanghera | General Electronics Discussion | 6 | 11-01-2004 05:58 PM |
