Results 1 to 10 of 10
Thread: is a dedicated video card essential?
    Registered draughted's Avatar
    Sep 2007
    australia
    i've bought a cheap IBM p4 to run emc, and it does, even with a intergrated video card.
    i then read after it not working on my first attempt that you need a dedicated video card. but do you really when it works without.
    i am asking because i also bought a pci card(fx5200) that will not work(won't load ubuntu). and i would like to know if i should take it back or find a driver.
    Sep 2007
    australia
    it seems to be worse with a dedicated than without.
    Nov 2005
    Do a latency test. If the latency is low enough for what you want to do and has no periodic long spikes with onboard video then onboard is fine.
    Sep 2007
    australia
    no, it needs it. the duration peeked at 300,000
    do you know how to load driver software for a video card that is not supported
    do i load the driver before i install the card
    i don't know but i can't load ubuntu with the card in.
    Nov 2005
    Try googling - installing Ubuntu video drivers - etc. The ubuntu community will have much more info on changing video drivers. I have done it but don't feel really qualified to give instructions. In ubuntu 6.04 and 8.04 You end up having to edit etc/X11/ xorg.conf , which means you need uses the sudo command to edit it....
    BMG
    BMG is offline
    Dec 2006
    Pennsylvania, US
    get a cheap video card from a local computer store for 10-20 bucks.
    Word of caution - Do not assume its the video outright.
    There could be other issues at work.
    First off - determine which motherboard you have
    Next - look at the listing of computer mobo's on the emc site to determine if its a problem machine.
    In the bios - start out with everything at default. Check latency
    Good Latency i - move to software setup
    Bad latency - Start disabling APCI/APM features - anthing to do with power management
    Retest Latency
    Good Latency - software setup
    Bad latency - Check if chip has SMI issues - if so - make corrections and retest
    Retest Latency
    Bad latency - Check Video setup (Intel 810 video has issues) - drop in a cheap video card and select a VESA or generic driver
    Retest Latency
    Good latency - Software setup
    Bad Latency - no your options with the MOBO are getting smaller - others here may have additional info
    Please note above that aside from your initial purchase, no added costs are needed for the first four items, you do not spend any money aside from your time researching and trying things out.
    Good Luck
    Registered acondit's Avatar
    Apr 2005
    Quote Originally Posted by draughted View Post
    The answer to your question really depends on the implementation of the on board video. I have two computers out in the shop, both of which have on board video. One of them works fine, the other I had to add an ATI Rage 128Pro 32mb pci video card to fix the latency. My computer that works with on board video has the Intel 810 video.
    If you look at the list of motherboards that are listed on the wiki, at least one of them has been used successfully with its on board video. So as someone else said test your board's latency and see if a separate video is needed.
    Alan
    Sep 2007
    australia
    ok, with a little help from linux beginners forum i was able to cut down the latency to 8000.
    Sep 2007
    australia
    what next.
    Registered cadmonkey's Avatar
    Mar 2006
    What next? If you've got stable latency of 8000 - that's a winner in my book. Get the machine running and make some chips
    Every day is a learning process, whether you remember yesterday or not is the hard part.
    www.distinctperspectives.com
    1. Need Help!- I can't install my video card! Help!
      By SpeedsCustom in forum LinuxCNC (formerly EMC2)
      Last Post: 12-19-2008, 05:08 PM
    2. Need Help!- ?s about 64MB Video Card.
      By Stampede in forum BobCad-Cam
      Last Post: 08-16-2008, 04:29 PM
    3. Surfcam Video Card Recommendations.
      By moldcore in forum Surfcam
      Last Post: 08-18-2007, 10:07 PM
    4. Best nVidia Video Card
      By pkaiser in forum Mastercam
      Last Post: 12-06-2006, 06:36 PM
    5. Picking a Video Card?
      By HPbyGD in forum Computers and Networking
      Last Post: 08-28-2006, 02:19 PM
