Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 02-03-2009, 04:20 PM
Chaka's Avatar
Chaka is on a distinguished road
Mechatronics 3 Axis Stepper Motor Driver
I am tring to set up EMC2 with this driver. Has anyone else used this board with EMC?
Old 02-04-2009, 09:20 AM
Big John T is on a distinguished road
I dont' see it here
http://wiki.linuxcnc.org/cgi-bin/emc...r_Drive_Timing
Do you know the minimum step and direction timing requirements of the board?
John
Old 02-04-2009, 09:54 PM
BMG BMG is offline
BMG is on a distinguished road
did not get to download the pdf (it wanted me to register for email) but if you look through the chip specifications from here, it should provide the timing requirements John asked about.
http://mechatronica.eu/nl/motion-con...fiers/stepper/
Shouldn't be any reason EMC can't run it.
Old 02-10-2009, 09:40 AM
Chaka's Avatar
This is actually from a different MECHATRONICS
This is the site of the manufacturer http://www.easy-cnc.com/
This is the unit that was purchased spec sheet
http://www.easy-cnc.com/web/download...3Axis(NEW).pdf
This is what we put together for making one-off engravings for labels on control panels. We recently used EMC2 on a project and we thought we would put this together for our own use.
Name:	Small Engraver.jpg
Old 02-10-2009, 10:10 AM
I didn't see any info on timing, you might contact the manufacturer.
John
Old 02-10-2009, 10:18 AM
Chaka's Avatar
In the quick start manual for Mach3 they list this
Is this what your looking for?
Name:	New Image.jpg
Old 02-10-2009, 10:42 AM
No, that has nothing to do with the timing requirements of the drive. The drive will need the step to be on for a minimum length of time and off for a minimum length of time so it will not miss a step. The same is true of the direction change bit. Easy thing to do is put a large number in there and if it doesn't go too slow your ok. With a 24 volt power supply you are not going to go very fast anyway. To start try 25000 for each one and see how it works.
Or contact the manufacturer and request the timing requirements I've only seen one that couldn't figure out what his board needed...
John
Old 02-10-2009, 12:07 PM
BMG BMG is offline
Can you read the name and model number of the driver chip? Allegro or something else? Looking at the site - you will have to pull it out of its holder under the heatsink.
Once you have that, you should be able to download the datasheet from the chip manufacturer which will have the timing data.
Old 02-10-2009, 01:21 PM
If you go that route make sure you add enough time on the chip specs for opto's etc that might be on the board and could change the overall time requirements.
John
Need Help!- Mechatronics 4axis stepper board ironaxe2008 DeskCNC Controller Board 1 01-01-2009 10:47 AM
3 axis stepper motor driver using a single PIC david90 PIC Programing / Design 5 04-05-2008 09:22 PM
Need Help!- Mechatronics Bi-Polar 4axis micro driver jf315 Controller & Computer Solutions 1 03-26-2008 03:50 PM
Beltdrive-stepper motor-stepper motor driver Georg Stepper Motors and Drives 0 10-16-2007 04:56 PM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 05:05 PM
