Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 02-03-2009, 03:05 AM
shing is on a distinguished road
Missing EMC2 Files
Hello,
I am an engineering student at the University of Auckland in New Zealand. I am currently trying to implement an MTConnect adapter to an already operational, EMC2 controlled Sherline machine tool. The adapter is designed for EMC2 and is provided as source code from the MTConnect website (www.mtconnect.org). When I try to compile the adapter, error messages come up caused by missing files:
g++ -g -I/include -I../src -I../include -c -o emc.o emc.cpp
In file included from emc.cpp:35:
emc_adapter.hpp:40:63: error: rcs.hh: No such file or directory
emc_adapter.hpp:41:43: error: emc.hh: No such file or directory
emc_adapter.hpp:42:22: error: emc_nml.hh: No such file or directory
emc_adapter.hpp:43:66: error: emcglb.h: No such file or directory
emc_adapter.hpp:44:61: error: emccfg.h: No such file or directory
emc_adapter.hpp:45:43: error: inifile.hh: No such file or directory
emc_adapter.hpp:46:24: error: rcs_print.hh: No such file or directory
emc_adapter.hpp:47:21: error: nml_oi.hh: No such file or directory
emc_adapter.hpp:48:20: error: timer.hh: No such file or directory
emc_adapter.hpp:80: error: 'EMC_STAT' does not name a type
emc_adapter.hpp:81: error: ISO C++ forbids declaration of 'NML' with no type
emc_adapter.hpp:81: error: expected ';' before '*' token
emc_adapter.hpp:82: error: 'LINELEN' was not declared in this scope
emc_adapter.hpp:83: error: ISO C++ forbids declaration of
'RCS_STAT_CHANNEL' with no type
emc_adapter.hpp:83: error: expected ';' before '*' token
make: *** [emc.o] Error 1
I have tried downloading these files and putting them into the folder to compile. This worked, however, another error came up caused by the code -lemc in the makefile. I looked into the meaning of this code and it appears there is an emc library file missing, libemc.so or libemc.a. I noticed that the code -lnml and -lemcini did not cause an error, and found the files libnml.so and libemcini.so were indeed in the library directory.
I am guessing that whoever installed EMC2 into this system may have left out some components, or I am working with the wrong version of EMC2 (v2.2.5). Can someone please have a look into their lib directory and let me know whether libemc.so (or .a) is present. If yes, please let me know how you installed EMC2 and what version it is.
Alternatively, does anyone know how I can install the library file? I have found the file libemc.a from the web but when I try to copy it into the lib directory, it says I do not have permission.
Sorry for the long read, I have been trying to get this working for almost a week now. Any help will be greatly appreciated.
Thank you,
Shing
Old 02-03-2009, 09:27 AM
cadmonkey's Avatar
cadmonkey is on a distinguished road
My guess is that it isn't intended to be put on top of an already running implementation of EMC2, rather a fresh compile, with this mtconnect source code included in the compile. I could be wrong since it appears you have to sign up to get access to any of the source, etc. I would try reading this - http://wiki.linuxcnc.org/cgi-bin/emc...04_from_source
Every day is a learning process, whether you remember yesterday or not is the hard part.
www.distinctperspectives.com
Old 02-03-2009, 12:58 PM
acondit's Avatar
acondit is on a distinguished road
I believe that cadmonkey is correct, in order to compile emc2 you need all of the source. When a binary installation is done, the source is not necessarily included. You can get the source either as a tarball or an anonymous cv checkout. If you are going to be doing a lot of work an anonymous cv checkout is preferable because you don't have to reload everything when you want to update things. If what you are doing is something that you might like to add to emc2, you should query the emc2 developers list about being added as a developer or at least how to go about submitting changes for someone else to commit.
Alan
http://www.alansmachineworks.com
Old 02-06-2009, 06:44 PM
Thanks for the replies. I will give it a try and compile from the source files, hopefully it will solve the problem.
Shing
Tool files missing tq9516pjm TurboCNC 8 03-19-2011 10:41 AM
Need Help!- Convert files to Inventor files. bartL Autodesk Software (Autocad, Inventor etc) 7 02-03-2009 11:38 PM
convert .dnc files to .plt files. feraldave General CAM Discussion 1 10-13-2008 04:48 AM
Problem- Missing pc and Ladder files for the Hitachi seiki hicell ca 20 Rinus CNC Machining Centers 0 09-19-2008 09:45 AM
Converting Illustrator files to Gcode files acoop101 General Metal Working Machines 1 06-05-2008 03:53 PM
