Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 01-07-2009, 08:54 AM
Arkwhizzard is on a distinguished road
Z Axis troubles
I have a small router that I would like to run on EMC2 all axis work well on the free Mach 3 down load. On EMC2 the X and Y axis work fine 1/2 step but the Z axis stalls and sometimes will start to move then stall then start in the oppisite direction even does this when moved manually (jog) I switched it to full step and play with the settings but I can't get a a reliable setting on the Z. It is a small router homemade with 65 oz Nema 17's 3 axis china controller and all axis move easily by hand (the Z only moves a flex tool holder). Any Ideas?
Old 01-07-2009, 09:58 PM
vlmarshall's Avatar
vlmarshall is on a distinguished road
It sounds like two of the windings on the Z stepper are reversed.
Old 01-07-2009, 11:07 PM
Not the windings
I checked but no I don't think that is it. All Three motors are identical 4 wire bipolar and I checked the Ohms across all three befor using them. The wiring to the controler bus is correct. Every thing runs fine on Mach 3 but I would really like to get it running and use EMC2 thank you for your response.
Old 01-08-2009, 09:30 AM
Big John T is on a distinguished road
Did you use the Stepconf Wizard to set up your config? Did you test the Z axis in Stepconf Wizard? The Z will most likely not be able to accelerate as fast as the X and Y due to it is lifting the Z mass. If you just tested the X and then used the same settings for the Z that might be your problem.
John
Old 01-08-2009, 12:05 PM
Step Config
Thanks John for your reply. When I set it up I used the wizard and did each axis separately. That is where I noticed that I was going to have trouble with the Z. When clicking on the test button the motor might hum or move a little. Letting off the button and clicking it again the motor would start and move like the other motors but you didn't know which direction it would go. This afternoon I am planning on looking into the Toshiba TA8435HQ5 data sheets to see if I can improve on the setup. I hope that helps.
Old 01-08-2009, 12:14 PM
The first thing I would do is to reduce the maximum acceleration for the Z then test it out.
John
Old 07-22-2009, 05:09 AM
CaptainVee is on a distinguished road
Check the table travel for the z axis using stepconf wizzard. It needs to be like -60 to 15.
I tried 15 to -60 and that froze the z axis.
Edit, placed this in the wrong tread.... Too enthousiastic I found a solution.
Have you run the latency test with the suggested "abuse"? I also had strange stuff going on with the z, just as you describe. I found that my latency numbers were too low and entered higher ones. This slows your machines speed but may get rid of those symptoms.
Sven
http://www.puresven.com/?q=building-cnc-router
Old 08-19-2009, 04:12 AM
dilbert0815 is on a distinguished road
AXIS ignoring the maximum speed of hardware
I have a similar problem as a newbe with my Z-axis loosing steps.
However in stefconf the test wents well and all my axis have different max speed limits.
Now when I get to AXIS display I get the feeling that those speed limits in the hardware conf are ignored by AXIS. With being adventurous I can get all axes to start the buzz of death (stall) by manuall control and moving the speed slider to higher values that the axis can realy do.
The axis speeds I can manually do in AXIS in fact are faster that during the tests in stepconf.
I tested in stepconf larger travel for all axes too so each axis has reached the top speeds during testing. So I'm pretty confident that it's AXIS (or the G-code interpreter) ignoring the hardware limits set in stepconf.
How is this supposed to be configured propperly ?
Peter
EDIT
Did a little more try'n'error today.
It seems that AXIS honors the speed setting in the configuration somehow.
But actually only one of the axes is honored and it's not the slowest one.
It seems to use X or Y as reference in my case and ignores the lower speed limit of Z altogether ...
Old 08-22-2009, 07:09 PM
Zig Zig is offline
Zig is on a distinguished road
DO NOT HAVE DIFFERENT ACCELERATION SETTING ON VARIOUS AXES.
Set all three axes to same acceleration.
Set all three axes to same maximum speed.
Old 08-22-2009, 08:36 PM
chester88 is on a distinguished road
Y do you say that?
  #11   Ban this user!
Old 08-22-2009, 11:24 PM
Zig Zig is offline
Chester,
The idea behind CNC control is to have multiple axes moving in a coordinated fashion in a multi dimensional space.
If the axes have differing accelerations then the motion can not be coordinated.
  #12   Ban this user!
Old 08-23-2009, 12:37 AM
During coordinated moves EMC only moves as fast as the slowest axis that is required to move,
but during rapid moves it will accelerator / cruise at each axis's maximum.
so having difference between axis is no problem and can speed up rapids.
I believe that stepconf may have not set the max velocity / acceleration settings properly.
As far as I can read in the manual in the INI file under the [TRAJ] heading
should have a MAX_VELOCITY and MAX_ACCELERATION entries.
This sets the coordinated move values I was talking about.
I am emailing the developers to ask about that as the manual may be out of date a bit.
Chris M
More LC30 troubles Fred T Okuma 0 10-02-2008 03:19 PM
Z axis troubles DSL PWR CNC Plasma and Waterjet Machines 9 07-22-2007 11:25 AM
air troubles wadetool Haas Mills 2 02-19-2007 03:30 PM
DXF troubles kung G-Code Programing 2 11-02-2005 03:41 PM
CAD Troubles Blackhawk General CAM Discussion 27 06-11-2005 10:13 PM
