Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 01-04-2009, 09:56 AM
Spunk is on a distinguished road
G02 and G03
Dear
I was testing the manufacturing abilitys in pro-e.
This works out fine but the G02 and G03 commands give the following errors in EMC for a sherline 5410 mill:
...zero radius...
...radius at begin differs from radius at end...
Could this have something to do with the rounded numbers? not enough number after the point?
Hope someone has had the same problem before.
Cheers
Philip
Old 01-04-2009, 11:33 AM
jpgdesigns is on a distinguished road
The I & J coordinates can be either absolute or incremental... check your post-processor settings... check EMC's settings.
I don't use EMC so I can't tell you what it is looking for or if there are settings to adjust...
Old 01-04-2009, 11:59 AM
The problem occurs at the very first time the G02 command is used.
all the numbers look okay, absolute (like i need them to be)
Old 01-04-2009, 01:08 PM
Andre' B is on a distinguished road
I do not think you can change the arc endpoint error setting in EMC like you can in other controls.
Can you try bumping up the number of decimal places you CAM software puts out.
I remember reading a while back (years) that 6 places was recomended for best results in inch mode, probably get by with 5 in mm.
Old 01-05-2009, 12:28 PM
So i need to get into the postprocessor in pro-e...
anyone know how?
Old 01-05-2009, 12:49 PM
Big John T is on a distinguished road
If it is the first arc only you are having a problem with then your post is not moving to the proper start position for the arc. Check your post processor.
John
Old 01-05-2009, 01:41 PM
According to the read-outs the cutter is in the right position to start the curve.
that is why I think that it has something to do with the accuracy...
Old 01-05-2009, 03:13 PM
Then the arc is defined wrong. Take a look at the Arc Buddy on this page.
http://wiki.linuxcnc.org/cgi-bin/emc...ode_Generators
It will generate the start position and the arc after you put in a couple of things. Then you can check your output to see what is wrong with your post processor.
John
Old 01-06-2009, 01:11 AM
i think i need ubuntu with EMC2 to do that?
now i have the standard issue EMC debian from sherline...
Old 01-06-2009, 06:57 AM
cyclestart is on a distinguished road
Any linux distribution worth it's salt includes python.
That wiki page has grown since I last looked ! The problem is it assumes people know what python is and how to use it. What percentage of the population might that be ?
Do this:
1) Right click "upload arcbuddy.py" on that wiki page.
2) "Save link as" and save it to your home directory
3) Open a terminal and type the commands
Code:
 chmod  a+x  arcbuddy.py
Code:
 ./arcbuddy.py
if you get a "bad interpretor" error, open arcbuddy.py in a text editor and modify the top line to read
Code:
 #!/usr/bin/python
and rerun the ./arcbuddy.py command in the terminal.
4} That's it. These scripts should also work in Windows with a python interpreter ? Think so anyway.
Btw: There's a quick text editor that can be run right from the terminal.
Code:
 nano  arcbuddy.py
The instructions are all listed at the bottom and take the form
Code:
"cntrl btn"   "some letter"
very handy and intuitive.
Anyway, just me up much to early and rattling on. Hope that helps in someway.
Edit/ There is a possibility another error might pop up. Depends on the python installed and what the gcode generator calls up. If another error shows up, just paste it here and someone will tell you what to install.
Anyone who says "It only goes together one way" has no imagination.
  #11   Ban this user!
Old 01-06-2009, 07:50 AM
owkay sure going to try it
but this is going to be a method to check, not to solve though...
i did the math and the places are pretty accurate but perhaps not accurate enough???
no-one knows something about pro-e postprocessors? can't be hard to tell him to print 4 or 5 digits after the point is it?
  #12   Ban this user!
Old 01-06-2009, 08:27 AM
ProE has it's own forum here. You could post the question there also.
Another option is telling ProE to use R's instaed of I's and J's. R's allow more fudge factor. I's and J's are the preferred way however.
