Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 01-04-2009, 04:32 AM
solskov is on a distinguished road
Sherline CNC mill
Hi there.
I am a beginner in cnc.
I am using EMC to control my Sherline CNC-mill.
Can anyone help me with G41 / g42 and g43.
My problem is how to call for the values in my program.
Henrik Solskov
Old 01-04-2009, 06:39 AM
cadmonkey's Avatar
cadmonkey is on a distinguished road
The RS274NGC manual - http://www.linuxcnc.org/handbook/RS2...RS274NGC_3.pdf
See pages 28 & 29 (pdf page #s 36 & 37)
As for "calling for the values in your program" I assume you are asking how to set the tool radius and tool length. Those need to be set in your tool table (tool.tbl in the directory that holds the configuration files is the default) - the documentation describes the format of the file, but the entries already in it are self explanatory. So to turn on cutter radius compensation to turn on cutter compensation left for a .25" diam tool, you need to have a .25" diam tool in your tool table file and program G41 Dt where t is the slot number for that tool. Same goes for the tool length offset. If you don't specify a tool (ie just programming G41) then the current tool is used, if you have already identified the tool number in the program or the current session with an M06 Tt (t again is the tool # from the table). If you haven't done that then the current tool is 0 which according to the tool table has a radius of zero so no offset is engaged.
HTH
Greg
Every day is a learning process, whether you remember yesterday or not is the hard part.
www.distinctperspectives.com
Problems with Sherline CNC Mill 44-henry Benchtop Machines 3 10-16-2008 05:19 PM
Sherline CNC Mill rgreenfield Benchtop Machines 4 02-03-2008 04:47 PM
Post for EMC and the Sherline mill mm AlfSkaar EdgeCam 5 08-20-2007 08:34 AM
My Sherline CNC Mill Coetzee Benchtop Machines 0 04-06-2007 10:44 PM
Help with Sherline Mill kellogs72 Benchtop Machines 5 11-04-2005 11:30 PM
