| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
OK .. we are all happy to have the new PC which runs like the clappers. Grat to have the USB and firewire ..and .. not so great to loose paralel port. Looking for a new PC to replace the existing machine runing EMC software. Paralel port is a must as is decent latency performance. Looking for advice and experiences with the modern ( still available ) motherboards suitable to run EMC. Any experiences welcome in particular anybody using the Jetway J7F2WE1G or J7F2WE2G boards. |
| Well seems no takers. Ok new motherboard has parallel port. An MSI board model K9 SLI V2 running with a dual core AMD Athlon X2 processor at 3.1GHz. On the face of it meets at least one requirement... runs like the clappers. mobo loaded with ATI X300 PCIX16 video card and 2 Gbyte of 667MHz DDR2 memory. Latency timing unimpressive. In facrt poorer latency timing than the old MSI KM2M Combo L ( about seven years old ) K9 latency performance greater than 14500ns Hope to have some figures on the jetway offering soon. |
I also found this in the archives of the EMC user list.
__________________ http://www.alansmachineworks.com |
| Hello Alan, Thanks for the response. Amajor problem is getting hold of some of these products. I have corresponded with Jetway but have had no joy in finding a suitable source In Australia. There are two companies listed as being able to supply but neither has stocks. One of them didnot seem to know waht they were promoting, asked me send em an email describing the hardware I was after. Anyway the great thing about Jetway offering is that itis also available in a 2 Gig version and that it also has a powersupply which will run off 24V ( mobile application). Presently all of my servo run off two 12 V car batteries. I am hoping to get the entire system to run of 24V and be to a certain extent isolated from mains supply; effectively keep batteries on chareg constantly and ensure no machine glitches in case of power loss. Spindle is varible frequency induction motor driven maximum voltage 33VRms at 100 K RPM. Will talk to driver manufacturers to see what can be done to proof it against supply variations Current computer will allow me to reach maximum speed of approx 230 mm / second ( approx 540 inches per minute ) with a resolution of 5 micron |
Jon |
http://wiki.linuxcnc.org/cgi-bin/emc...ixingSMIIssues If so, have you had any overheating problems? Thanks, Will Baden |
I think this whole idea of putting extremely marginal cooling on laptop CPUs and then throttling the CPU speed to prevent overheating is really shoddy design. It would be like not putting a radiator on a car and then shutting down the engine whenever the inevitable overheating occurs! Jon |
| Here is a list of computers/motherboards that have been tested and their results.. http://wiki.linuxcnc.org/cgi-bin/emc...l?Latency-Test sam |
From what I can tell I would have to build a machine from that webpage, and since I am not very well versed on building a PC I am kinda shy to put one together. Thanks, Will Baden |
#10
| A few hundred dollars down the road and some new data to hand. The old MSI Athlon ( 1.9 Ghz i think ) motherboard KM2M Combo ( MS-6738 ) with latest bios is offering latency figures in the 18000 nS area. Good for high speed traverse of about 240 mm/sec The later MSI K9N SLI V2 motherboard with a dual core X2 processor at 4.8 GHz ( i think ) is good for a latency figure of 22 000 and correspondiglu lower high speed traverse of 205 mm/ sec which is a disapointing figure given a much higher performance of a dual core cpu. Granted its graphical performance is better than the older PC. Hope these numbers are of help. |
#11
| Sexy motherboards and graphics are not necessarily the cats meow for EMC. If you look at that list, one of the best latency results came from a compact Deskpro EN. Not necessarily curring edge technology. If you are planning on setting the computer to just run EMC, then why not get an older model as Jon suggested for little money. For me, I got a bunch of computers from work for free - they were just building up and inventory to make a trip to the recycler so I saved them a trip. EMC just works provided the latency is low and the MOBO is a reasonably fast machine (PIII and 600MHz is current minimum standard). For servos, it is my understanding that the latency times are less critical as compared to steppers (Corrections from others if I am mis speaking here). General consensus reading the EMC mailing list lately is that new motherboards are sacrificing realtime for graphics and "game performance". For EMC Realtime latency minimums for the MOBO dominate MOBO speed comes second |
#12
| IMHO this is one of the biggest PITA's with EMC2 - finding a motherboard that will play nice! Most cheap and cheerful motherboards have integrated GFX these days, and even if you can turn it of and use a VESA driver, you do actually want decent OpenGL performance to run the Axis GUI. I also don't want a PC the size of a filing cabinet to drive my machines, so I tried using an old Mini-ITX board I had lying around. With 6.06 it worked fine, but with 8.04 it wouldn't produce sensible latency results, even with the VESA driver! I've ended up with a very painful install of the latest 8.04 kernel on a reinstalled 6.06 system, just so I can have the same RT compile platform as my other machines, but a working GFX driver. For me, hoping to find useable motherboards from the second hand market isn't an option - I want to be sure I can hot swap a dead motherboard for something new that I can get on next day delivery. What I would like to know is can motherboards with bad latency results in the high-speed thread work OK if the step generation is being done in hardware instead of S/W? Alternatively, can EMC2 be run on a machine without X at all? I have mine setup to run emcrsh with a gui on a remote machine, but EMC doesn't seem to want to run on the main machine unless X is running. Cheers. |
| Fanuc 3t motherboard HELP! | NID | Fanuc | 2 | 12-15-2008 04:45 PM |
| Need motherboard! | KurtsKustom | Want To Buy...Need help! | 0 | 04-21-2008 07:40 AM |
| Problem- Dead Motherboard | ger21 | Computers and Networking | 7 | 04-06-2008 07:48 PM |
| New motherboard/processor | spoiledbrat | Computers and Networking | 5 | 05-29-2007 08:52 AM |
| Mach 3 and ITX Motherboard? | DennisCNC | Mach Software (ArtSoft software) | 2 | 11-21-2005 09:04 PM |
