| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
i am trying to put 3 home switch xyz on my gantry router and use emc2 to setup the home position. i have install the switch with a pull up resistor and everything. my problem is that when i home the axis, the table move and pressing on the switch. before it back off the switch, it pop an error"switch inactive before back off move". i am getting the same error for all axis. i have try both NC and NO switch but nothing work on emc2. i try the switch on "mach3 demo" and it work great with no error. it make want to buy mach3 instead of using emc2. any help on wiring switches on emc2 would greatly appreciated. machine: gecko 210 driver nema34 motor cnc4pc c10 breakout 48v power |
That being said, here is the relevant section from my ini file for the x axis HOME_OFFSET = -0.1 HOME_SEARCH_VEL = -1.500 HOME_LATCH_VEL = 0.250 HOME_USE_INDEX = NO HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 1 This says that my home switch is -0.1" from X0, that I search for home in a negative direction at 90ipm, that once I hit home I back off and search again at 15ipm, that I don't use an index in addition to the switch, that I ignore limits when searching for home and finally that the X axis is the second axis to home. I have Z set to HOME_SEQUENCE = 0 and Y is also set to HOME_SEQUENCE = 1. So it homes Z first and then X and Y simultaneously. If I was sharing a switch loop between multiple axii, then I could not home two axii simultaneously. I am using NC switches with two switches on a for each axis and the switch at my home is the same as the limit for that end. Each loop goes to a separate input pin. Good luck, Alan
__________________ http://www.alansmachineworks.com |
| Off the top of my head I wonder if your search speed is too high allowing the switch to open again before homing is finished doing it's thing. You need to tell us more info about what you did and what settings you are using as well as what version of EMC. |
| i will try to play with the setup config ini file again tomorrow, the weather is too cold to play around in the shop. now my z axis home switch stop working, no respond at all even when i change to a different input pin. x and y still work. my x axis motor is mess up, it go -x ok but when it go in +x it just stall and make a whining sound. all these just happen today when i start it up to run some test on it. it drive me nut. my finger and toe is about to be frozen if i stay in the shop any longer. i will try it again tomorrow. thanks everyone. linux: emc2 ubuntu 8.04 current setting: home offset = 0 home search vel = .1 home latch vel = .06 home ignore limits = yes |
| limit switch and home switch setup | Runner4404spd | General Electronics Discussion | 0 | 12-15-2005 07:58 AM |
| Is it possible to use the home switch as the limit switch as well? | Darc | Mach Software (ArtSoft software) | 2 | 10-23-2005 12:50 AM |
| Limit Switch / Home Switch in Software | Sanghera | General Electronics Discussion | 6 | 11-01-2004 05:58 PM |
