Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 12-04-2008, 12:45 AM
margni74 is on a distinguished road
Help determining latency and EMC timing parameters....
I'm trying to determine the latency numbers for my machine.. I ran 'latency-test' with an older Althon XP 1.350Ghz w/256MB Mem....and got the following from the window that popped up:
Maximum Jitter
Servo Thread: 48686
Base Thread: 61464
Max Interval
Servo: 1045191
Base: 85769
How do I apply these numbers to the StepTimingCalculator spreadsheet:
From the G320 specs:
Step Pulse Frequency 0 to 250 kHz
Step Pulse “0” Time 0.5 Microseconds Min.
Step Pulse “1” Time 3.5 Microseconds Min.
I can then fill in Required Step Length and Required Step Space... not sure what to put for 'Required Direction Setup', 'Required Direction Hold'. I guess 'Worst Case Latency' is derived from the output of 'latency-test'???
Old 12-04-2008, 08:03 PM
anyone??
Old 12-05-2008, 01:26 AM
chester88 is on a distinguished road
Have you read this?
http://wiki.linuxcnc.org/cgi-bin/emc...StepGeneration
Worst case Latency comes from the latency test.
'Required Direction Setup', and 'Required Direction Hold' are special setting for drives that need extra time to for those comands.
Old 12-05-2008, 10:15 AM
Big John T is on a distinguished road
Interesting that the G320 manual does not mention the direction setup and hold times. You might do a search in the Gecko forum to see what you find or ask directly in the Gecko forum. When you find out I'll update the wiki site step direction page:
http://wiki.linuxcnc.org/cgi-bin/emc...r_Drive_Timing
It is much less painful to get a step direction config going if you just use the Stepconf Wizard do generate your config files. Then you can add to or modify the custom files as needed.
Take a look at this short getting started guide.
http://www.linuxcnc.org/docs/EMC2_Getting_Started.pdf
A SWAG on your direction setup 1000us and 20000us for direction hold.
John
Old 12-05-2008, 04:05 PM
Originally Posted by chester88 View Post
Have you read this?
Thanks for the info... btw, it looks like 'latency-test' doesn't actually spit out the worst case latency #'s... It appears that you have to actually run :
sudo mkdir /dev/rtf; sudo mknod /dev/rtf/3 c 150 3;
sudo mknod /dev/rtf3 c 150 3;
cd /usr/realtime*/testsuite/kern/latency; ./run
/usr/realtime-2.6.12-magma/testsuite/kern/latency$ ./run
in any case the 'lat max' is hovering around 11000ns, with and average of 470ns or so. ovl max is 12000ns.
According to the wiki, an ovl max less than 15000-20000 ns should yield nice results
Software for determining the parameters of threaded products shgshg Product Announcements & Manufacturer News 0 11-04-2008 05:37 AM
EMC2 latency from Network card randyf1965 LinuxCNC (formerly EMC2) 1 03-22-2008 10:08 PM
Determining the master PCB on 10T guhl Fanuc 7 01-23-2008 01:40 AM
Latency, Jitters & Lost Steps Imagineering TurboCNC 22 07-22-2005 07:39 AM
Determining VA load Swede General Electronics Discussion 11 04-10-2004 04:00 PM
