Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 11-29-2008, 01:44 PM
Marfon is on a distinguished road
The engine works but only in one direction
Hi everyone,
it's m.y first time writing in this forum.
My name's Luca, i'm 30 and i'm italian. I've finally done my first test with my Pluto-p, in configuration lathe-pluto, at the moment with just one engine.
As a h-bridge i've used the 298 one . I've linked the pluto pin 28 and 29 to the encoder, the pin 20 to input 1 and 21 to h-bridge enable.
I send to input 2 the opposite signal of input 1 with a not.
Everything seems to work! The pid works only if i rotate the engine in one sense. Measuring the voltage with the tester on the pwm pin, it varies from 0to 3,3 v, and it doesn't happen if i rotate the engine in the opposite sense: on the pwm pin i have 0 v.and the pid doesn't work.
Can you help me suggesting some solution?
Thank you
Luca
Search drawing from free piston engine ->stelzer engine Enginetuner I.C. Engines 17 08-27-2010 08:11 PM
Bit for Works auvecu CNCzone Club House 0 07-02-2007 12:58 AM
It works!!!! KLeeper CNC Wood Router Project Log 5 05-10-2007 12:46 PM
Another one in the works.. CRFultz CNC Wood Router Project Log 31 12-23-2004 01:09 AM
G41 and G42 How are works ? bunalmis G-Code Programing 24 08-11-2003 08:10 PM
