Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-13-2008, 12:02 PM
DanC is on a distinguished road
Interpreting Driver timing
I am using IM483 drivers (Intelligent Motion System). I found these specs in the user manual in a table named 'Logic Input Timing', but I am not clear how I interpret them for the driver timing settings in EMC.
(Specification) (Input) (Time)
Min Pulse Width, Reset, 500nS,
Min Pulse Width, Step Clock, 75nS,
Typical Execution Time, Step Clock, 100nS,
Typical Execution Time, Direction, 100nS,
Would Step Time be 75nS or 100nS? and Step Space?????? Directin Hold and Setup??????
Any insight into understanding this data and/or how to determine these settings would be much appreciated.
Cheers,
Dan
Old 10-13-2008, 01:58 PM
Big John T is on a distinguished road
One of the EMC gurus says
75ns steplen, 100ns stepspace, 100ns dirspace, probably 100ns dirhold
I got that like this: steplen=step clock width, stepspace="step execution time", dirsetup and dirhold both="direction execution time"
That is the fastest timing I've ever seen so if it does not work increase the values and test in the Stepconf.
If this is ok let me know and I'll add it to the list at wiki...
John
Old 10-13-2008, 02:34 PM
Thanks Big John T. I'll let you know how those work out once I install EMC.
i want to cut timing pulleys , so help !! max_imum2000 General Metalwork Discussion 18 08-08-2008 12:16 PM
THC Timing? Red Earth CNC Plasma and Waterjet Machines 27 04-16-2007 10:03 AM
Timing Belts .200 xl elogicca DIY-CNC Router Table Machines 1 11-13-2006 08:09 PM
Timing Pulleys h_2_o Benchtop Machines 7 02-02-2005 10:26 PM
Timing Belts chas DIY-CNC Router Table Machines 1 01-19-2005 09:03 AM
