Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-08-2008, 01:41 AM
DrStein99's Avatar
DrStein99 is on a distinguished road
Instal not using Ubuntu
Last night I ran update manager on my system which appeared to uninstall EMC2 from my system. Luckily, it seems the config directory still exists so I didnt lose my .ini and .hal files. Lightly reading the install doc's, it appears that it's geared to install in Ubuntu dapper, which I think is an older version I think after I did the update, it installed as Hardy.
Ideally, I would like to install EMC2 to a Centos 5.2 system. Are there tarballs that exist so I can do the usual ./configure, make / install - or would I just be creating a mess, and should stick to using Ubuntu?
-Erich
WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
Old 10-08-2008, 08:19 AM
cyclestart is on a distinguished road
I've seen that upgrade option in the update manager window and avoided it like the plague. My guess is you have borked the emc install. Could be wrong, choose the RT kernel at bootup (if it still exists) and see what happens?
The current advice from linuxcnc appears to be;
If you are happy with Dapper continue to use it
If doing a fresh install go with Hardy
Running something other than Ubuntu is swimming upstream. Don't even think about it unless there is a very compelling reason.
Anyone who says "It only goes together one way" has no imagination.
Do you have to use ubuntu? phantomcow2 LinuxCNC (formerly EMC2) 11 10-03-2010 06:46 AM
water pan instal on bolt together 4x4 Kmanco Torchmate 6 03-20-2008 01:00 AM
Ubuntu 6.06 vs Ubuntu 7.1 piedpiper LinuxCNC (formerly EMC2) 12 01-13-2008 11:41 AM
not ubuntu Mr Bits LinuxCNC (formerly EMC2) 22 12-19-2007 08:12 AM
Can I instal Win XP over Win 98 please? ImanCarrot Computers and Networking 18 02-12-2007 09:15 PM
