Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 09-27-2008, 04:43 PM
peetle is on a distinguished road
EMC2, System Management Interrupt Problem
Hi all,
I just finished my JGRO CNC router and I have been running it with EMC2 on Hardy Heron. I have latency issues which appear extremely similar to the ones described on the EMC2 wiki here (System Management Interrupt takes place every 64 seconds).
However, after doing the suggested fix on their website, I still have the same intermittent jump in latency.
I know that the smi fix is running because i can see it in visible when I list modules (lsmod). Is it possible that the fix is not working for some reason? As I was using hardy heron, I knew I didn't need to compile a new version of the module.
I'm quite the newbie to linux and CNC so any help would be very appreciated.
~Peter
Old 09-27-2008, 05:33 PM
samco is on a distinguished road
Great work.
Now - if you are still getting overruns.. I would look at other things. Do you have onboard-video? (video cards that share memory with system memory)
what is your system?
sam
Old 09-27-2008, 07:34 PM
Samco - thanks for responding.
The computer is not very fancy. It is a P4 1.8 Ghz or so desktop with a video card which I think is an older matrox. It is not an integrated graphics card.
Old 09-27-2008, 07:38 PM
I should also reiterate that the overrun takes place about every 64 seconds and seems to take the exact same form as an SMI issue.
Also, are there visual indications based on the output of the router that would signal a latency issue? I notice that all my work with the router seems to be successful and then suddenly a significant amount of steps are lost. The router then continues and this process repeats itself.
Would it be helpful for me to send some pictures of the output?
Old 09-29-2008, 06:46 AM
thedoctor is on a distinguished road
SMI and latency problems
Don't look at the output to the drives for any indication of a problem. Stay with the latency issue as tested in terminal. The descriptions on fixing SMI latency problems are a little sketchy, as are other EMC documents. They don't tell you that certain chipsets are not supported. See if your chipset is even being detected by watching it boot REAL carefully. You might see a screen that says INTEL not detected or something similar. Also, other stuff runs at the 64 second interval. All power managment stuff should be turned off/disabled. I believe the video issue can be proven to not exist by running the latency-test without doing anything to provoke the video RAM. Just start the test and sit there. Hang in there. It took me three weeks and four computers to get a good clean system running with help from this forum and others. Almost forgot! Have you got 500meg of RAM? It really helps.
Old 09-29-2008, 07:16 AM
also look in the bios. I solved one computers problem by turning off the power saving 'stuff' in the bios.
sam
Old 09-29-2008, 07:18 AM
lspci -v will also give you your chipset info..
sam
Problem with manual moving in emc2 ad_Wolf LinuxCNC (formerly EMC2) 6 06-30-2008 05:05 PM
Problem with power managment in EMC2 ad_Wolf LinuxCNC (formerly EMC2) 9 06-13-2008 04:59 PM
Need an example of GibbsCAM post processor supporting Tombstone Management System Captain_Nemo GibbsCAM 0 01-16-2008 03:51 PM
Need an example of GibbsCAM post processor supporting Tombstone Management System Captain_Nemo Post Processor Files 0 01-16-2008 03:42 PM
Weird Problem Possibly Due To EMC2 juzwuz LinuxCNC (formerly EMC2) 5 12-20-2006 01:53 AM
