| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hi I'm building a new controller for a leath using EMC. Most of the electronics in the leath were lightning struck, so were junk, the heavier stuff was OK. Using two parallel ports, I have every thing mostly working under control of EMC except the stepper motors... They are apparently a high end (for their day) 5 phase motor with 10 leads in a non-stared configuration. The drive amps are OK, so will reuse them, but they need a +/- 8 volt 5 phase sine wave to drive them. The manufacture (South Bend) had used a micro processor to control 5 digital-to-analog convertors. This way they could make a sine wave that could be run at a wide range of frequencies and even frozen or reversed. Slick. I dicided to follow their lead and do much the same thing, just with a bit newer processor. Has anyone already done something like this? If so, do you have a design or any design tips that could save me some hassle? I'm a bit undecided if it would be better to use step/dir. or speed/dir. control. It seems to me that speed and direction would be better as it would involve less communication between the PC and the signal generator via a parallel port. |
| I would have thought the deciding factor would be what EMC prefers to control them with. Creating a 5-channel sine wave from a step/dir signal using a current microprocessor with internal or external DACs is relatively easy and there's sample code around for ATMEL and PIC processors that would give you a head start (albeit 2 phase, but the concepts are similar). As I understood it your choices are step/dir for stepper drivers or speed/direction plus encoder so that EMC plays the part of a servo controller. I suspect the latter is infinitely harder to get working effectively and efficiently but no doubt someone will be along in a minute to contradict me... |
| Yes I had to generate multiple analogue control voltages with a micro. I used atmel ATmega16 with linear technologies D/A converter chips sitting on I2C buss. All A/D chips sit on same clock and serial data line the micro uses one of the ports to select which A/D is to be updated. You can write a look up table to do the appropriate D/A output , a modulo 5 counter to select the correct channel and voila Bob's Your uncle. The beauty of this scheme is that the D/A converters retain last analogue value This gives You a fairly quick update rate for a five phase output. from memory update rate was about 14 clock cycles per channel. I used this to control gains and AGC loops in an RF signal processor but same same |
| 5 Phase/ 5 wire stepper drivers. | jonandyev | Open Source Controller Boards | 64 | 02-29-2012 07:56 PM |
| Sine Plates, Sine Bars, Sine Fixtures . . . | widgitmaster | General Metalwork Discussion | 7 | 05-09-2011 08:27 AM |
| Vexta 5-phase / 10 Wire Steppers | peiboy | Stepper Motors and Drives | 7 | 08-18-2009 01:17 PM |
| sine wave Linear Encoder ?? | Danii | Linear and Rotary Motion | 1 | 11-01-2007 08:44 AM |
| Gettys N360 three phase half wave | bsharp | Servo Motors and Drives | 7 | 08-05-2007 09:06 PM |
