Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 09-23-2008, 07:46 AM
s3r4ph is on a distinguished road
Question Axis is Mirrored
I have a Homebuilt CNC machine, running HobbyCNC motor package, I have EMC2 on Ubuntu 8.04 installed on my PC and everything seems to run well, except for one problem: My X-axis is inverted. Everything looks like it's coming out mirrored (text read right to left, etc).
Can anyone help me fix this?
I'm pretty new to CNC machines and to EMC2, but not electronics an Linux.
Thanks.
Old 09-23-2008, 10:45 AM
acondit's Avatar
acondit is on a distinguished road
You can swap the A and /A leads on your X drive or you can
go into you ".ini" file and put a "-" sign in front of the X-axis scale value.
Alan
http://www.alansmachineworks.com
Old 09-23-2008, 11:25 AM
Yeah, I figured I could switch the wires, but was curious of any software adjustment.
thanks
Old 09-23-2008, 05:21 PM
acondit's Avatar
thanks
So, did you get it fixed then? Which did you use?
Alan
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 01:54 PM
Mirrored solid - one good TP one bad TP ajinjax BobCad-Cam 3 10-25-2007 01:59 AM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
Strange toolpaths from mirrored surfaces. Jim Estes BobCad-Cam 12 01-14-2007 10:18 PM
Output is mirrored?? BobLWeiss Carken Products (Deskam, DeskCNC etc) 3 01-03-2005 11:54 AM
