Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 09-15-2008, 11:17 PM
123CNC is on a distinguished road
Servo Power and loop error?
I'm using Mesa 5i20/7i33/7i37 and Axis display to run analog servo cards. I wanted to be able to switch the AC side of the servo amps DC supply so that one could do other controller/ PC tasks when not running and not have to listen to the Servos sing.
I realize I could probably tune the amps better to reduce the sing, add it to my to do list. Going with the shutting off the amps route, I trial tested by connecting the amp's ssr to the Axis manual "FloodOn" hal pin. This seemed to work well. Wanting to leave the flood output available for flood, I added some buttons via pyvcp. Turning the amps on via the pyvcp button seemed to make the steady state/ no motion loop unable to maintain the 0.0001 position that it was able to when fired from the "FloodOn" pin. Other routes to fire the output seemed to have the same problem. If it were physical wiring difference I would suspect signal noise. But this occurs when just changing the software link /'wiring.' The amp power is a discrete output, so I wouldn't think this would make any difference as far as threads and or realtime. But if that's it, what are my options besides 'Mist' and 'Flood' to link to my amp power?
Old 09-16-2008, 11:31 AM
PCW_MESA is on a distinguished road
If you are using 7I33s, the amplifier enable outputs are probably the most appropriate signals to enable your amplifiers. These are active high (high when amplifier is enabled) 5V CMOS signals which can drive TTL inputs, OPTO couplers, or SSRs
Peter Wallace
Old 09-21-2008, 11:31 AM
Roguish is on a distinguished road
I agree with PeterW. Disable the drive and it should quit singin'. Don't drop power, especially to the encoder, and you won't loose position. Careful if you have a vertical axis. Vertical axes should have holding brakes.
Old 09-22-2008, 03:17 PM
7i33t power and drive enable
Peter,
I tried the enable output. However, I currently power the 7i33t via the pc 50 pin cable, so the output goes high as soon as I power on the PC. Would rather not add another power supply to 'external' power of the 7i33, but will consider it.
I was hoping that there was some easy software fix to power my amps on and off. I'm just a little surprised and baffled why the built in pin/signals from 'flood or mist' verses a new link via pyvcp is so different or would even effect either the control loop or the encoder/error feedback.
Old 09-22-2008, 08:55 PM
Peter,
The enable output of the 7I33 will be low when the system is first powered (Note this is not the enable signal on the 50 pin cable, it an inverted and buffered 5V signal ), and only go high after EMC has enabled the DAC outputs. They will go low again when EMC is exited or the PC is powered down.
These signals (4 = 1 per 7I33 analog out) are intended for just this purpose: deferring enabling amps until the software has initialized the interface hardware. They should alo work fine for your purpose (disabling your AMPs when EMC is not used)
With the new 5I20 Firmware (HostMot2), these enable outputs will also go low on watchdog timeout
Peter Wallace
Open Loop to Closed Loop Stepper Conversion beamhome Stepper Motors and Drives 9 05-24-2012 02:46 AM
question on closed loop vs open loop (servo systems) boonie Servo Motors and Drives 20 11-09-2007 12:30 PM
Closed loop vs. open loop pelesl Benchtop Machines 10 04-06-2007 04:56 PM
Lathe conversion - open loop vs closed loop bhowden General Metal Working Machines 7 03-21-2006 03:56 PM
Closed loop....open loop? DAB_Design General Electronics Discussion 10 06-26-2004 04:02 PM
