| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
| Just recently I bought a 3 axis cnc board which was tested and does work on kcam. I myself have tested the board on a trial of kcam and it does work. Here is the million dollar question, the pin setup calls for an x Ebable (as for y and z). I've tried to leave the pins that call for " (x,y,z) Enable" as unused but to no avail. From what information I have seen my answer lies with Hal. I have no clue what to do in order to get my board working with emc2. Whats more my board's manual was translated from spanish to english, which = alota giberish. Thanks in advance! here is my board's called for pin setup 1 OPORT+20INVERTEDSPINDLE RELAY 2 OPORT0 NORMALX-STEP 3 OPORT1 NORMALX-DIR 4 OPORT2 NORMALX-ENABLE 5 OPORT3 NORMALY-STEP 6 OPORT4 NORMAL Y-DIR 7 OPORT5 NORMAL Y-ENABLE 8 OPORT6 NORMAL Z-STEP 9 OPORT7 NORMAL Z-DIR 10 IPORT+16 NORMAL NU 11 IPORT+17 INVERTEDX-HOME SWITCH 12 IPORT+15 NORMAL Y-HOME SWITCH 13 IPORT+14 NORMAL Z-HOME SWITCH 14 OPORT+21 INVERTEDZ-ENABLE 15 IPORT+13 NORMAL NU 16 OPORT+22 NORMALM CODE FUNCTION 17 OPORT+23 INVERTEDM CODE FUNCTION |
| If the pins are ENABLE active high then leaving them unconnected may in fact not enable axes. You need to connect the enable pins to a logic high in order to get them going. In the first instance take a voltmeter ( set it to DCV ) and measure the voltage on ENABLE pins with board powered up and nothing connected to pins. It should probably read less than 1 volt. Take a resistor of a few hundred ohms ( just to contain smoke on the input ) and hook it up to +5v and the pin and again measure pin voltage. Should be close to 5 Volts and the axis should be active. If the voltage is below four volts then you will need a buffer to drive the enable pins. Solution 1) permanently tie the enable to +5volts... may be an unsafe option. Solution 2) tie enable to +5 volts via E-Stop pushbutton activated relay Solution 3) In configuration wizard you will be able to select which pin from paralle port is machine enable ( sorry do not have software to hand to check exact name) Feed the enable pin signal via a buffer and through E_Stop activated relay to the axis enable pins. E-Stop interlock gives you added level of safety. |
| Tags |
| cnc, emc2, enable, manual, pin setup |
| Enable shift key for Fanuc 6M. | ckirchen | Fanuc | 3 | 02-04-2012 04:13 AM |
| Enable signal on KL-4030 bad? | LaserLad | Automation Technology Products | 0 | 09-11-2008 10:22 AM |
| Mazak EIA enable parameter | Bakes1 | Mazak, Mitsubishi, Mazatrol | 2 | 01-12-2008 01:17 PM |
| How to enable the sloter to be more forceful? | Syphonics | Mechanical Calculations/Engineering Design | 11 | 02-04-2007 11:45 PM |
| Connecting Amp Enable | keithorr | CamSoft Products | 5 | 03-21-2005 05:31 PM |
