Results 1 to 2 of 2
Thread: XYZ-standart G-code => ABC-not standard management
    Sep 2008
    Uzbekistan
    Exclamation XYZ-standart G-code => ABC-not standard management
    Good time of the day!
    I have one question on realization management tool.
    It Is Given:
    1. G-code, XYZ - standard.
    2. Soft EMC2 (linux-Ubuntu) and Mach3 (WindowsXP)
    3. Output given from soft A(x)=X, B(y)=Y, C(z)=Z
    On output:
    The Crossbar engines on axises A,B,C - not standard.
    Necessary to realize the functional dependency output given from soft to motor:
    The Example:
    A(x,y)=sqr(x*x+y*y)
    B(x,y,z)=(x*x+y*y+z*z)/(2*x*x*y*y)
    C(x,y,z)=(x*x+y*y-z*z)/(2*x*x*y*y)
    May 2008
    I know nothing about Mach 3 but a bit about EMC2 so my answer here is probably only applicable to that system.
    Quote Originally Posted by Arcad View Post
    The Example:
    A(x,y)=sqr(x*x+y*y)
    The EMC2's kinematics should be able to handle these formulas.
    Take a look at some of the existing kinematics files at kinematics source. I'd start there with trivkins.c. It is a set that uses motors that exactly match allignment with Cartesian x,y,z,a,b,c,u,v,w. From there look at some of the transformation source like rotatekins.c and you'll quickly catch on to how machine pose is related to motors on non-trivial systems.
    The puma and scara kinematics should also help understand complex relationships if you are familiar with the design of these machines.
  1. Tool Life Management
    By Jake E. in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 11-05-2009, 02:13 PM
  2. Looking For A Job- Management/CNC Machinist
    By Kaymen in forum Employment Opportunity
    Last Post: 08-12-2008, 03:01 PM
  3. pocket standard
    By Beaker in forum Mastercam
    Last Post: 11-29-2007, 07:00 AM
  4. Help with non-standard pac-sci stepper
    By Argofanatic in forum Stepper Motors and Drives
    Last Post: 08-21-2007, 07:43 AM
  5. Standard Ballscrews
    By rhino in forum Linear and Rotary Motion
    Last Post: 05-13-2006, 07:24 PM
