Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 09-03-2008, 01:40 AM
dfro is on a distinguished road
EMC2 on Ubuntu Studio 8.04.1, kernel 2.6.24-19-rt
I have a computer running Ubuntu Studio 8.04.1, kernel 2.6.24-19-rt.
After doing the emc2 install script downloaded from the linuxcnc.org site, and restarting my computer, I noticed that the kernel 2.6.24-16-rtai was now on my grub boot screen.
When I tried to run emc2 in my 19-rt kernel, it would not work.
When I tried to boot Ubuntu Studio into the 16-rtai kernel, the computer got hung up on the splash screen.
Here is the log when I tried running emc2 in the 19-rt kernel:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.24-16-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=/usr/bin/inivar
HALCMD=/usr/bin/halcmd
EMC2_EMCSH=/usr/bin/emcsh
EMC2_IOSH=/usr/bin/iosh
EMC2 - 2.2.6
Machine configuration directory is '/home/dfro/emc2/configs/sim'
Machine configuration file is 'axis.ini'
INIFILE=/home/dfro/emc2/configs/sim/axis.ini
PARAMETER_FILE=sim.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=emc.nml
Starting EMC2...
Starting EMC2 server program: emcsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=8364
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
insmod: can't read '/usr/realtime-2.6.24-19-rt/modules/rtai_hal.ko': No such file or directory
8364
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -9
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
/usr/bin/emc_module_helper: Invalid usage with args: remove rtai_ksched
Usage: /usr/bin/emc_module_helper insert /path/to/module.ext [param1=value1 ...]
where module is one of:
rtai_math
rtai_sem
rtai_shm
rtai_fifos
rtai_up
rtai_lxrt
rtai_hal
rtai_sched
rtai_smi
rtai
rt_mem_mgr
adeos
rtl_time
rtl_sched
rtl_posixio
rtl_fifo
rtl
mbuff
the path starts with one of:
/lib/modules
/usr/realtime
and the extension is one of:
.ko
or the module is in the directory /usr/realtime-2.6.24-16-rtai/modules/emc2
OR
/usr/bin/emc_module_helper remove module
where module is one of the modules listed above.
ERROR: Module rtai_hal does not exist in /proc/modules
Is there a way to get emc2 working in Ubuntu Studio with 19-rt kernel or do I need to have a fresh install running the 16-rtai kernel?
Thanks,
dfro
Old 09-03-2008, 07:33 AM
Ray Henry is on a distinguished road
dfro
The fresh install will be the quickest way to get it going. That install could be a separate boot.
You'd have to sign up but I'd post this to the developers list at sourceforge. That's where you are more likely to get the attention of folk who understand and can offer specific kernel and real-time related help.
Old 09-03-2008, 10:28 AM
I'll do that.
Thanks,
dfro
HELP!!! Sherline/Ubuntu 6.06/EMC2 - Configuration Telle Benchtop Machines 15 03-21-2009 05:54 AM
Any plan for Ubuntu 8.04 + EMC2? david_geng LinuxCNC (formerly EMC2) 22 05-19-2008 08:43 PM
TROUBLE W/EMC2 UBUNTU 6.06 DOWNLOAD Gads LinuxCNC (formerly EMC2) 2 01-22-2008 08:10 PM
Ubuntu 6.06 & EMC2 tenmetalman LinuxCNC (formerly EMC2) 19 10-11-2006 09:23 PM
New live Ubuntu 6.06 with EMC2 samco LinuxCNC (formerly EMC2) 0 09-20-2006 09:32 AM
